Any one use Plastic Renew on the gas tank?
3 replies to this topic
  • ecarlson
Posted February 09, 2001 - 10:13 PM
I need new graphics and was wondering if I should use Plastic Renew on the tank first and then apply the Graphics. Any suggestions?
  • Hick
Posted February 09, 2001 - 10:45 PM
I did this to a KX 500 with good results, the better the sanding job the better the results. You will probably need more paper than is provided with the kit.
I was worried about messing up my tank so I sanded only where the graphics went but it came out very nice. I sold the bike a few months later so I don’t really know how it held up, but the graphics adhered very well to the treated areas of the tank.
Hope this helps!
  • Guest_Guest_*
Posted February 12, 2001 - 07:24 AM
Make sure you put the graphics on AFTER the plastic renew - I put the renew on first and the graphics peel it off and fall off right away. Put the graphics on first or be really disappointed!
  • Guest_Guest_*
Posted February 12, 2001 - 07:28 AM
Yikes, I am an idiot, I just read my post and don't know how I came up with that. Here is what I meant:
1) put the graphics on first
2) put the plastic renew on after
Because:
The plastic renew can be easily peeled off by stickers. I put my renew on first, then wrecked all my graphics when they fell off with the plastic renew stuck to them. Then I had to sand off all the plastic renew (hard because it chunked up into crystals), put the graphics on and then re-apply the renew.
