Need Some Help!
3 replies to this topic
  • dewercs
Posted September 06, 2008 - 08:07 PM
Ok, this is a model specific question so please don't move this thread. I'm a 250/450 B rider that is a pretty good mechanic and my suspenion is set up with proper sag and a reasonable set up, the suspenion is stock but well maintained. I ride a 07 yz250f and 07 yz450f, I'm having more of a problem with the 450. Last season I had no problem at all and the bike handled like is was on rails. This year when I turn into a turn and start to lean the bike the front tire is breaking loose, I ride on intermediate to hard pack dirt, I hav used bridgestone intr. and hard pack, and maxxis intermediate and hard pack tire with a wide variety of tire psi settings... in other words I have been testing! What I don't get is nothing has changed from last season except I have been changing tires and psi settings to try to find some grip. I'm open to any suggestions. I reviewed video footage of my rideing and my form and body position looks good and is the same it was last year. I had a couple thoughts of fork oil hieght may be to high or taking out a little sag to put more wieght on the front wheel, but it is the same as last year. Sorry for the long post, and advice is greatly appreciated!!
Also what front tire are you guys using?
  • Desracer
Posted September 06, 2008 - 09:04 PM
Check for pressure build up in the fork legs? The front end skids its to stiff.
  • dewercs
Posted September 07, 2008 - 07:45 AM
I have been bleeding the air before each moto.
  • DAVID146
Posted September 07, 2008 - 08:16 AM
Check The Rear Nitro Level Or Rebuild Both Front And Back You May Have A Oil Breakdown Or Some Broke Parts In The Front.
  • Hot  36 replies
  • 0 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
Need help by Goforaride
  • Hot  68 replies
