Over tighten main sump drain bolt!
4 replies to this topic
  • Follett
Posted June 14, 2002 - 12:51 AM
Took it to dealer and they fitted heli coil and all was ok until I changed the oil again and now there is a very slow leak from the bolt. Can anyone suggest a fix for this? Too scared to tighten any more! Thanks
  • sirthumpalot
Posted June 14, 2002 - 01:20 AM
Use a new washer and tighten to spec. If strips you can always remove the helicoil and tap the nut out to the next larger size. I'm guessing that would be stronger than a helicoil. Maybe someone else has better advice?
  • Flamed1
Posted June 14, 2002 - 03:13 AM
Follett,
I too did the same thing including installing a helicoil. My slow drip went away when I went to a Ty Davis magnetic drain plug which also included a new washer. No more problems.
Good Luck,
Brian
  • lewichris
Posted June 14, 2002 - 04:53 AM
if you take out the helicoil make sure to put in a timecert.
Chris
  • SFO
Posted June 14, 2002 - 05:27 AM
Since Yamaha has created a porthole in the side of the threaded boss in an attempt to insure full oil drainage the sump thread is very easy to strip.
It is also very easy to heli-coil or timesert it crooked as well.
If the sealing face of the washer is not flat against the fastener surface it will drool.
Good luck with this one...
