engine Oil leaking from air box!!
3 replies to this topic
  • ak567
Posted September 05, 2008 - 01:22 PM
On my 08 wr450f I noticed that the air box was leaking black oil (engine oil). I opened the side door and the bottom was full and it was slowly dripping out the side door. I could see some small spatters on the air filter. Any idea whats going on here. I cleaned it out to stop the leaking.
  • maxtherat
Posted September 05, 2008 - 01:35 PM
Probably too much oil in the motor and the crank case breather is spitting oil into the air box. At leasty i think the newer wr's are routed this way.
  • SJMC_DON
Posted September 05, 2008 - 01:38 PM
You have too much oil in your motor, make sure you are using the step by step procedure to change your oil - specifically draining from both plugs and removing the dipstick before draining:prof:
It's all right here -
http://www.thumperta...t=oil in airbox
  • ckroto
Posted September 06, 2008 - 10:14 AM
Yup, just like they said, too much oil. I only know from experience....oops:ride:
