o6 yz450f keeps dying at an idle
6 replies to this topic
  • soafcoi
Posted September 02, 2008 - 04:58 PM
i have an 06 yz450f thats been rode pretty hard,never any problems before.i think i might have gotten hot the last ride ,did the oil,cleaned the filter ,but now once i start it and ride it for a minute it want to die if i let the throttle drop to an idle then it gets tricky to start again,but if i keep on the gas its just fine. Can any tell me why this is happening and maybe how to go about fixing it?:thumbsup:
Posted September 02, 2008 - 05:00 PM
What happens if you simply raise the idle speed? (big silver slotted screw, left side.)
  • WB450
Posted September 03, 2008 - 11:34 AM
Check to see if your pilot circuit screw fell out, it happens.
  • RJacks
Posted September 03, 2008 - 02:16 PM
Yeah, That's it. I believe it would idle a bit higher.
  • WB450
Posted September 03, 2008 - 06:22 PM
No, it won't idle at all. Welcome to TT.
  • MacJammer
Posted September 03, 2008 - 07:01 PM
the timing chains are crap on '06s. Pull the cam cover off and try to position the timing marks at top dead center. If you cant get it then you timing chain has stretched and jumped a few teeth. MY '06 did this same thing at about 15 hours of riding. 2 more teeth jumped on my exhaust cam and it would have been kaboom. I replace my timing chain once a year now. They are 13 dollars at any Yamaha dealer. Check it and make sure.
  • soafcoi
Posted September 03, 2008 - 08:13 PM
thnx macjammer i will check and see how my timing is im leaning more in that direction because i have checked the obvious like the others have mentioned above,i was wondering if maybe it would have something to do with valves or top end?
  • 0 replies
  • On January 15, 2017
  • Hot  50 replies
  • 10 replies
