WR450 '07 Vampire
9 replies to this topic
  • yamita
Posted August 28, 2008 - 12:23 PM
Hi to all, i'm a happy WR450 '07 owner from Italy, i would like to ask if you also have this big problem about fuel consumption.
With my previous WR450 '04 i had an autonomy of approx 95km/59mi and with reserve i went to 110km/68mi, now with the '07 mod i can do approx 70km/43mi and with reserve 80km/50mi.
That's really nasty, what did they do to this engine?
Is that only a problem of my bike or you experienced it too?
Thanks.
  • tweav
Posted August 28, 2008 - 12:44 PM
the 07 has a smaller fuel tank then the older bike.
  • yamita
Posted August 28, 2008 - 01:41 PM
You are right, sorry i forgot to mention i had on my '04 the fuel tank of '05, i obviously compare the consumption of '04 and '07 starting from the same tank capacity, 8Lt/2,11gal.
  • yamita
Posted August 29, 2008 - 11:05 AM
Can you please tell me wich is your autonomy with the 8Lt/2,11gal tank?
  • wartsnuff
Posted August 29, 2008 - 12:33 PM
Thanks.
i do at least 100km without using reserve driving hard.. on a 08 WR450....
cheers
Warts
  • yamita
Posted August 31, 2008 - 12:01 PM
That's a dream for me... I cant reach 100km also using reserve :thumbsup:
Trying to fix carburation, hope to get better results.
  • William1
Posted August 31, 2008 - 12:14 PM
Range is extremely dependant on terrain. Unless the bike you compare to is riding on the exact same terrain under the same conditions, be it wet or dry, comparing is fruitless. My mileage varies by nearly 100% from tight single track (23mpg) to fire roads (close to 50 mpg).
  • Fullbore4
Posted September 01, 2008 - 09:34 PM
Yamita......that does sound like a lot of fuel consumption for any WR. My 06 WR450 gets between 28 and 36 mpg. As you know, it depends on how aggressively you work the throttle, just like driving a car, etc. Does it act like it is running rich?
  • yamita
Posted September 02, 2008 - 03:54 AM
You both are right but my driving style is the same as previous and i ride also in the same places, tried to fix carburation but nothing changed, now i try change jets, hope this helps.
  • Fullbore4
Posted September 02, 2008 - 07:41 AM
Let us know what you find out.
