WR426 Odometer Pick Up Cover Removal Question
7 replies to this topic
  • critter
Posted December 27, 2002 - 03:17 PM
I saw a post on removing the odometer cover on the front wheel and putting a YZ seal and spacer in place of it. Has anyone done this ??? I see no room to install the seal. I'm a little "corn-fused" by this. :) :D
  • sabin
Posted December 28, 2002 - 12:35 PM
On 2002 wr426 the hub is not the same as the yz and there is no way to put yz spacer...
  • critter
Posted December 28, 2002 - 02:02 PM
Yeah....I found that out after I bought the parts and opened them. :)
  • HaremScarem
Posted December 28, 2002 - 02:46 PM
I just left the hub in place and used a piece of Heat Shrink over the cable inlet. I Squeezed off the open end of the tubing with some pliers while it was hot.
  • mmbasa
Posted December 28, 2002 - 03:36 PM
I went to Home Depot and got a rubber cap for 30cents and stuck it over the top. works like a charm and its color coded.
  • sabin
Posted December 28, 2002 - 08:40 PM
I remember seeing somewhere a replacement aftermarket spacer with the form of out obo part but from aluminum with seal in it, but cannot remember where...
  • bigdrtrdr
Posted December 29, 2002 - 08:07 AM
My 01 WR 426 has a Zipty racing spacer 9.95 and a yz seal 6.00 in it whats so different about the 02?
  • GPS Dual Sport
Posted December 29, 2002 - 08:22 AM
The 02 models got a new front hub that is wider than the old unit. I owned both bikes and the old trick of using the YZ seal and spacer will not work anymore.
I have seen the Al covers that use the odometer drive seal on this web site. These folks at b&b aluminium are from down under. web page is clickable here
I'm not sure if the spacer will fit the '02 hub. There is a difference in the diameter. I could not fit a '01 odometer drive on my '02 front wheel.
For my '02 I just removed the odo cable and put a tight fitting plastic cap like some of the other folks here did.
