WR250R/X Gearing Information
Posted 02 July 2010 - 09:05 PM
Posted 03 July 2010 - 09:53 PM
Posted 08 July 2010 - 05:27 PM
Posted 09 July 2010 - 10:21 AM
Posted 10 July 2010 - 09:47 AM
Posted 11 July 2010 - 02:43 PM
Posted 21 July 2010 - 06:39 PM
http://cgi.ebay.com/...sQ5fAccessories
Posted 14 September 2010 - 08:23 AM
Posted 08 October 2010 - 05:25 AM
Posted 06 November 2010 - 09:17 AM
Question: I want to pick up a little grunt in the lower end. My WR has great mid and top end, but lack's the snap down low. Will a High Performance sprocket like a Supersprox with the aluminum core and steel teeth increase my low end with out adding teeth to the back sprocket (because it's so light weight)?
I dont want to go with a 12T front because I hear it's bad on your chain life...
Your thought's, anyone...?
My front is 13T and the back is 43T
Posted 06 November 2010 - 10:46 AM
O-zone said:
Not too likely you'll feel anything like more low-end grunt by merely changing to a lighter-weight sprocket.
I've been reading that all my riding life, and, honestly, I never saw any kind of difference with chain wear with a 12-tooth front sprocket.
My chains and sprockets still seemed to last just as long as if the bike had a 13 or 14-tooth front sprocket, and I believe what kind of terrain and maintenance they recieve is a mucho bigger factor.
Your WR-250R is simply geared too high for trail riding with the stock sprockets, and Yamaha Motor Co. knows that.
It came with those sprockets in order to satisfy some regulation, not because it's the hot setup.
Same as why it comes with lean FI settings and a plugged-up muffler with a cat. converter inside of it.
On my WR-250R, I used 12/47 sprockets, and it felt great.
Yeah, the engine will turn more revs while cruising on the street, but the bike is a 250cc dual-purpose rever, not an 1,800cc Gold Wing that idles down the highway all day.
That's my opinion, anyway.
Posted 06 November 2010 - 08:52 PM
With your thought's in mind. I think I will start with the 47 in the back and then the 12T in front, if the 47's not enough.
Guessing I will need to add a new chain to that list:) Thinking 110 link?
Starting from square one:)
Posted 06 November 2010 - 10:24 PM
Tell the bike shop guy to go ride his Gold Wing.
Posted 07 November 2010 - 09:31 AM
Posted 07 November 2010 - 09:18 PM
How's your low end grunt?
I'm pretty new with adjustments like this, so forgive all the silly questions...
Sure love this forum:)
Edited by O-zone, 07 November 2010 - 09:53 PM.
Correction...
Posted 08 November 2010 - 08:19 AM
Last few times I had my GPS with me I've topped out around 85-87MPH.
Low end grunt is significantly better. Wheel comes up on throttle alone in 1st and 2nd. Much better in the loose stuff too.
Quote
Nothing to forgive, that's what forums are for. Ask away
Posted 13 December 2010 - 02:16 AM
I use my WR250R for off road only, before the change would only use 1st & 2nd gears, sometimes 3rd.
Now I am using 1st to 5th, climbs up steep hills with total control, and same for downhill.
Forget about 1 or 2 more horsepower here or there, this is the best mod to wake up the WR250R and make it extremely user friendly off road.
Posted 03 May 2011 - 09:06 AM
Posted 20 February 2012 - 04:49 AM
elfraz, on 03 May 2011 - 09:06 AM, said:
Yes, it will work with the oem chain. I have a 12/45 set up and the oem chain works for that, also. I guess I should add mine is a WR250R...I'm assuming the swing arm length and chain length (108 links) are the same on the X model.as the R.
Edited by DragonNester, 20 February 2012 - 04:56 AM.
Yamaha WR250R (2012) |
Follow us:
