suspension 08 WR450
9 replies to this topic
  • idamoh
Posted August 26, 2008 - 02:50 PM
My fatass weighs 250, 270 with all my gear, and I am 6'6". At the very least I need to upgrade my springs. I called FC and they reccommend a .50 for the forks, and a 6.7 for the rear. The increase for the forks seems correct to me, but I questioned the guy about the 6.7 in the rear. He told me because of my height I will tend to ride with more weight over the rear of the bike. Any other tall guys out there run across the same scenario? Does this seem reasonable? I wanted to check before I spend the money. I looked into Race Tech, but it looks like the biggest spring they carry for the front is a .48.
  • longie
Posted August 26, 2008 - 08:14 PM
On my '06 YZ450, I ran 7.0 rear spring and on my CRF450 I ran a 7.4. And I am healthy like you.....
  • STECKNINE
Posted August 27, 2008 - 08:00 AM
Factory Connection is correct! You husky fellas will need that spring rate:p I figured out that the Race Tech spring rate was wrong! They had me set up for a 5.6 spring rate. I think F.C. has me set up with a 6.7 spring rate and, I weigh 180. Factory Connection is the way to go with a WR suspension. I just rode yesterday and, I love my suspension! It just sucks up the whoops. I have the YZ forks on my WR and, full F.C. re valve. It is by far the best up grade that I have done for this bike.
  • SXP
Posted August 27, 2008 - 08:52 AM
There is NO WAY you are going to need a 6.7 kg/mm rear spring at 180 lbs. Some thing doesn't compute!
Did you mean 5.7?
  • longie
Posted August 27, 2008 - 12:24 PM
No, a 6.7 spring is needed for a much healthier rider than 180 lbs. Try a 5.7-5.9....
  • STECKNINE
Posted August 27, 2008 - 01:14 PM
No, a 6.7 spring is needed a much healthier rider than 180 lbs. Try a 5.7-5.9....
My bad:confused:you are right! Sometimes i need to wake up before I post on the Internet.:thumbsup:
  • beezer
Posted August 27, 2008 - 01:32 PM
We won't argue with someone your size.
A revalve is gonna be needed too.
A buddy is humongous too and has to mess with every bike he buys and then put it back to stock when he sells it.
  • idamoh
Posted August 27, 2008 - 01:40 PM
Thanks for the advice guys. I am gonna go with the FC spring. I can't wait that stock suspension has been killing me.
  • tribalbc
Posted August 28, 2008 - 08:37 AM
Eibach has .50 fork springs for the WR. Just make sure you get the 970 series not the 969's that the TR catalog states. The 969's are 20mm too long. I just went through this on my 07 :worthy:
Race Tech just uses Eibach springs anyways :thumbsup:
  • Roger_Steck
Posted September 05, 2008 - 06:57 PM
I have a 07 WR450 and weight in with gear right at 280. I run .49's in the front and a 6.4 in the back. The free sag and static sag on the rear is right on and a little shy on the front.
Roger
