Just upgraded from 03 to 07 WR450
12 replies to this topic
  • coloradobrad
Posted August 25, 2008 - 03:23 PM
I just picked up an 07 WR450 for $3900 :worthy: It's totally stock and like new. I've been reading and searching the archives. TT rocks :thumbsup:
Anyway, here are my notes so far. Any comments or advice is appreciated.
1. Air filter cage hole - The hole is "fixed" but I'd rather have the new cage
Part # 5TJ-14458-00 Service bulletin # M07-001.
2. Free Mods - grey wire, snorkel, throttle stop, AIS, removal, pea shooter
- Which AIS? DIY, GYTR, TT
- GYTR AIS # -> GYT-5TJ93-69-01
- Maybe an aftermarket pipe. FMF Q4?
3. Carb - jet it for 8500 ft - creeping & WOT - Rocky Mtns yeah!
- jetting YZ needle or GYTR mystery needle or JD kit?
- Which YZ needles are people using? 2006 Standard Needle for 07?
- What's a NCVQ needle? What's an EMR needle?
- Which fuel screw. Old WR has Zip Ty but may not be best option.
- accelerator pump (AP) o-ring or wire tie mod
- AP screw 1/2 turn mod?
- what's ACV?
stock jetting is prob pretty good for 8500 ft:
mj 162
pj 45
leak 60
start 65
paj 70
maj
needle nfnt
future jetting tbd:
4. Skid plate - flatlands, scorpion, TT (Utah Sport), etc
- leaning towards flatlands
http://flatlandracin...duct_Code=24-40
- TT pic
http://utahsportcycl...e/wr450fpic.htm
5. Unabiker Rad Guards FTW!
6. New tires
- front D756
- rear D756 or Maxxis IT?
7. New black wheels
- front rim is bent a tiny bit - straighten? doubtful.
- have silver rims annodized black or buy new? which rims? hubs?
8. TBD
- Hand guards
- TrailTech from 03 WR or new?
- +2 sprocket on rear?
- graphics
- maybe new gel seat or ?
- mount Scott's stab from 03 WR --> SUB mount? bar risers?
- AVS controls? or local guy's replicas? RMCP
- new tool kit - wrap style?
  • jams229
Posted August 25, 2008 - 06:07 PM
That's quite a list. It's a good thing you only paid $3900, because you can easily spend another $3900 in the after-market world...
  • coloradobrad
Posted August 26, 2008 - 11:50 AM
Yeah. No kidding!
  • wr 400 mikky
Posted August 30, 2008 - 10:05 AM
thats ll well n good, but how does the bike compare to your old one, give us a write up when you`ve been out on it eh?
  • yamita
Posted August 31, 2008 - 11:54 AM
I did almost the same change as you (from '04 to '07) can you tell me wich is the fuel consumpion of your bike also compared to old one?
I noticed on mine a very big consumpion increase.
  • coloradobrad
Posted September 15, 2008 - 01:08 PM
Just finished my 2nd ride on my "new to me" 2007 wr450. I like it so far but I miss a few things about my 2003. Both bikes are uncorked and jetted. The 03 has an FMF Q-pipe and my 07 has a stock pipe.
1st off the stock 07 pipe sucks! On my 1st ride the low-end was horrible and the bike wouldn't rev high enough at WOT to even hit the rev limiter. I gutted both baffles and yanked the pea-shooter...wow what a difference but OMG it's loud! Sound tested at 106 dB @ 4500 rpms. Unacceptable :banana: I'm picking up a like new Leo Vince X3 in 1 hour for $125 :excuseme: It has 94db, 98dB, & 102 dB inserts
Power delivery is smoother on the 07 but the low end doesn't hit as hard as my 03. I wonder if the Leo Vince X3 will fix that :lol: My 03 is a wheelie machine and I miss that. I wonder if the lower CG of the 07 is holding the front down or if it's a low end power issue. Any thoughts?
Suspension... Both bikes are set-up stock. I def need to tune the suspension on the 07. It's harsh compared to my 03 and I just don't have the confidence in the whoops etc.... and that 07 seat just works my arse.
Handling... The 07 feels ~25 lbs lighter, waaay skinnier, and much more nimble. :excuseme: The front-end feels much "looser" and squirly than my 03 though. The arm-pump kills me. I have a Scott's stab on the bench that should fix that. I never really needed it on the 03. BTW, this comparison is based on the 03 WITHOUT the damper. The 07 will def be easier to ride once I dial in the susp and get my stab mounted.
Fuel consumption... TBD
  • coloradobrad
Posted September 26, 2008 - 08:23 AM
9/26/08 Progress Update
New cage installed
2. Free Mods & exhaust - grey wire, snorkel, throttle stop, AIS, removal, pea shooter
- GYTR AIS kit installed part # -> GYT-5TJ93-69-01
- Leo VInce X3 s/o installed
- GYTR mystery needle installed
- System-tek brass tipped fuel screw
- accelerator pump (AP) o-ring mod complete
stock jetting was ok for 8500 ft:
mj 162
pj 45
leak 60
start 65
paj 70
maj
needle nfnt
8/21 jetting:
changed leak and needle
mj 162
pj 45
leak 40
start 65
paj 70
maj
GYTR Mystery needle position #3
o-ring mod
9/25 jetting:
Prior jetting too rich. Changed main and clip position based on PMs w/
Mtn-Track, this post and extrapolating RAD from well liked sea level jetting tables
mj 152
pj 45
leak 40
start 65
paj 70
maj
GYTR Mystery needle position #2
4. Flatlands skid plate installed
5. Unabiker Rad Guards installed - new style guards are amazing!
6. New tires installed
- front D756
- rear Maxxis IT
7. New black wheels - tbd
8. Trailtech Endurance installed
9. 54 sprocket installed on rear -> 54/13
- stock 120 link chain wouldn't fit
- bought +4 link chain and cut it back 2 links
10. Scott's stab + submount installed
11. TBD
- Hand guards - Cycra?
- graphics
- new tool kit - gytr wrap style?
  • Mtn-Track
Posted September 26, 2008 - 09:10 AM
Were you able to stuff that 54 rear sprocket in there with the stock chain? I know I can fit a 52 on mine but I don't think a 54 will make it with the stock chain and guide....
  • coloradobrad
Posted September 26, 2008 - 10:06 AM
No. I should of mentioned that... :lame: I had to replace the chain. I bought +4 links from stock (120 vs 124 links?) and then cut it back 2 links.
  • Mtn-Track
Posted September 26, 2008 - 10:46 AM
Got it! I still have too much life in my chain to swap it out just yet, so I'll go with a 52 rear for now. Thank's!
  • tribalbc
Posted September 26, 2008 - 04:34 PM
Why wouldn't you just run 12/50 :lame:
Same final gear ratio as 13/54 :bonk:
I ran that for a season on my 07 but now run 13/52
  • coloradobrad
Posted September 27, 2008 - 07:04 PM
Good point. I already had the 54 tooth and then installed it. I found out the chain wouldn't fit and bought a new chain in hast because I wanted to ride that day. In hindsight 50/12 would have been the way to go.
  • Mtn-Track
Posted September 29, 2008 - 05:31 AM
A 12 on the front is a pretty tight chain wrap, so I stayed with the 13. I also wanted to move the rear wheel as far forward as I could to help out in tight/quick turns.
