oil change purge bolt
4 replies to this topic
  • tea spoon
Posted August 24, 2008 - 05:14 AM
howdy, just finished breaking in my new 08/450wr and gave her it's first oil change. followed manual to a tee. when i cracked the purge bolt on cylinder to check for oil flow was getting what I thought I should. Now there was oil comming out but not a real flow like I am use too seeing on most of the other stuff I work on. is this normal or is it a concern. PS used 10w40.
:thumbsup:
  • buggs bunny
Posted August 24, 2008 - 07:41 AM
i have a 08 wr450 to, and when i opened that bolt it just kinda drooled out then i shut it.then rode forty miles on next ride with no problems.i'm sure you'r alright.:worthy: :thumbsup:
  • William1
Posted August 24, 2008 - 08:10 AM
he bikes use a low pressure, high volume oiling system. Ooze is fine. Also, unless you think there is a oiling problem, there is never any need to 'purge air' from it. You change the oil and filter, start the bike, let it idle for a minute or so, checking for leaks, any air will of purged on its' own.
  • neevothespaniel
Posted August 25, 2008 - 03:56 AM
Isn't this the oil pressure check bolt. When opened slightly oil should leak out gently to show you have good oil pressure.
  • tea spoon
Posted August 25, 2008 - 05:12 AM
Thanx for the replys, 200km yesterday and I rode like I stole it and all was fine.:thumbsup:
