Pulled apart my 08 with lots of hours on it, guess what I found
4 replies to this topic
  • AnotherRedHead
Posted August 22, 2008 - 07:02 AM
I wouldnt even want to guess the amount of hours Ive got on my 08 yz450. Ive had it for a year, and I ride 2-3 days a week, I would think a safe bet would be to say I put 4-6 hours a week on it. I do change the oil every time I ride however. So, prob 200 plus hours on my motor, I havent even lifted the valve cover, I know i know, but it still starts fine. Im only pulling it apart to put in the piston I got from Ron Hamp and to check it out.
So my valves were still in spec, every single one of them. Ti valves look brand new after getting blasted, seats are perfect.
Only weird thing, I always use a hammer and a small socket to get the cotter out of the retainer to get the valves out, and when I did this, two of the valve springs broke, they were very very very brittle. I must have somehow side loaded them a bit, but careful inspection shows I didnt even nip the side of the machined spring cup in the head. Kinda worried me as I would think that any kind of operation would be more pressure on the spring than what I did to remove the valve cotters.
No matter, new springs from yamaha and its back together, with lots of compression and a bark like a factory yamaha....Just doing some heat cycles and then I'll put her on the dyno. Changed the clutch and frequent oil changes (mobil1 15-50) obviously help, Im an abuser and a deep sand railer, and the clutch was still decent after a year, threw in a new one for the freshened motor.
After going through this bike, I am realizing how nicely and carefully designed this chassis and engine is. There are reasons its so smooth and quiet, and there was much thought that went into every aspect of this motor. I am very impressed with yamaha quality and engineering.
  • Ga450owner
Posted August 22, 2008 - 07:12 AM
shhhhhhhhh don't tell anyone. YZFs are notorious for valve failure and top end failures :thumbsup:
The valve spring thing is a little concerning - did you replace all of them?
  • AnotherRedHead
Posted August 22, 2008 - 10:48 AM
Yeah, I replaced them all. Bike is strong, super strong. 52rwhp first pull
  • erickdj
Posted August 22, 2008 - 03:14 PM
what was the reason to change the piston? old one worn out? or just for more performance? what other performance mods does your bike have besides that piston?
  • AnotherRedHead
Posted August 23, 2008 - 05:55 AM
We cleaned the casting from the ports, didnt remove any material, just tootsie roll. There is a bad short side radius on the intake and exhaust sides. Stock cams, stock springs, just the 13.5 piston from RHC. Its a custom design from Ron Hamp, I hear the off the shelfs are junkers. Doesnt use a secondary ring. Ron also bored my carb a few months back, helped alot, even with the bone stock motor. Oh yeah, and a Ti4 pro circuit.
Bike retains all the characteristics of a stock motor, but with the hit of a mod450. I love this combo with the stock cams, tons of hit and midrange. My last bike (RHC honda 450) had a cam and it shifted the power to a higher rpm range....
