How much metal is acceptable in an oil filter?
26 replies to this topic
  • nickeenoo
Posted August 21, 2008 - 08:02 PM
Hi All,
I just did an oil change and decided to cut the filter apart and stretch out the pleats to see how much metal was caught in the filter. I was surprized to see how much there was. How much metal is normal? I will try to post pics a little later. The bike is fairly new with only about 40 hrs on it.
Thanks,
Nate
Posted August 21, 2008 - 08:06 PM
How much time does the filter have on it?
  • nickeenoo
Posted August 21, 2008 - 08:45 PM
7-8 Hours. Normally I wouldn't go quite this long - usually 5-6 with Amsoil full synthetic (Thanks Gray). Also, I change the filter everythime I change the oil.
Here are the pics:
http://i440.photobuc...oo/IMG_0989.jpg
http://i440.photobuc...oo/IMG_0986.jpg
  • desert-rat660
Posted August 21, 2008 - 08:47 PM
u hard on the clutch?
  • nickeenoo
Posted August 21, 2008 - 08:55 PM
Not typically, although this last ride was in some technical rocky sections and I did have to adjust the clutch a few time throughout the ride; I was fanning the clutch a lot.
I did have a hard sand ride on this batch of oil; don't know if that matters or not.
  • desert-rat660
Posted August 21, 2008 - 08:58 PM
its probably from the clutch, is the clutch stock? i think the stock plates in the 450's are aluminum. i changed mine out to an ebc kit.
  • nickeenoo
Posted August 21, 2008 - 09:01 PM
The clutch is stock. Still, is that a normal amount of metal? It looks to me that at this rate I'll be replacing my clutch about every three rides.
  • desert-rat660
Posted August 21, 2008 - 09:09 PM
get an aftermarket clutch with steel plates, like the ebc kit i got
  • desert-rat660
Posted August 21, 2008 - 09:10 PM
what year is your bike
  • nickeenoo
Posted August 21, 2008 - 09:12 PM
It's an 07.
  • desert-rat660
Posted August 21, 2008 - 09:24 PM
ive never had that much metal in my filter, but it all depends how u ride the bike. it seems excessive. is it aluminum shavings? steel?
  • desert-rat660
Posted August 21, 2008 - 09:32 PM
i believe stock plates are steel for the 07/
Posted August 21, 2008 - 10:57 PM
To me, that looks excessive. I especially don't like the look of the curled chip in the pleat at the far left pleat, half way up. I suspect something dragging against a case somewhere.
  • Ga450owner
Posted August 22, 2008 - 06:59 AM
No it is not normal for a 40hr bike
You are hammering the clutch......and it will need help very very soon unless you change the habit.....or the terrain you ride on
  • nickeenoo
Posted August 22, 2008 - 07:27 AM
I just checked with and magnet and about 95% of the shavings were aluminum. In my excitement over the amount of metal shavings in the filter I forgot that I did just install a TimeSert in my oil drain hole. I thought I was quite careful to remove all the metal shavings from the install but maybe not. I will change the filter again and see if there is any more shavings. Until I change the filter again, I will assume there were some leftover shavings from the TimeSert install.
Next time I'll try to remember what I've done to the bike before I get my panties all twisted :thumbsup:
Thanks,
Nate
  • bigred455
Posted August 22, 2008 - 11:50 AM
The driven plates are steel not aluminum,that does look like a little too many shavings.That drain hole for the oil filter ,with the bolt out there is a open end that leads right into the clutch side ,outside tranny side etc.Was the inner clutch case off when you did the time insert?I am guessing not.
  • desert-rat660
Posted August 22, 2008 - 11:55 AM
u should look into a reusable filter, it will save u $$ in the long run. just a thought
  • nickeenoo
Posted August 22, 2008 - 01:39 PM
It was not. It probably should have been. I'll be interested to see what the next oil change looks like.
  • nickeenoo
Posted August 22, 2008 - 01:40 PM
I've been thinking that for some time. Maybe the time is right.
Posted August 22, 2008 - 02:07 PM
I've been thinking (a reusable filter) for some time. Maybe the time is right.
Step up and buy the Scotts. The quality is well worth the difference.
  • 5 replies
  • Hot  28 replies
  • 10 replies
