06 yz 450
7 replies to this topic
  • Chris_Presbyto
Posted August 21, 2008 - 05:36 PM
have a question how do you get the freakin spark plug out of this bike? do you need a special tool ? also having popping / backfiring on decel put 45 pilot in plus moose fuel screw now fuel screw does nothing. was able to tune out pop with stock 42 and stock fuel screw but fell out next ride ever since I have had a problem. bike is new bought as left over. thanks.
  • sacfelix
Posted August 21, 2008 - 05:41 PM
In order to get the plug out make sure the socket has the little rubber insert in or use a 3/8 hose and push it on the end. On my 06 yz450 I'm running the following:
48-PJ
170-MJ
GYTR fuel screw 1-3/4 turns out
NCVS neddle in the 3rd clip position
This makes my bike rip all the way around.
Posted August 21, 2008 - 05:44 PM
You need the tank off to begin with, then just a 16mm plug socket and an extension.
Either the Moose screw is made wrong, for the wrong model, or you either forgot the O-ring, or possibly left the OEM one in place and jammed it up in the bore when you installed the new screw.
  • desert-rat660
Posted August 21, 2008 - 05:48 PM
u can sneak the plug out if u use a spark plug socket and a3/8 universal.
  • mxdon1
Posted August 21, 2008 - 08:03 PM
Once I losen the plug up I use a magnet with an adjustable extension on it that is like an inspection mirror.
Posted August 21, 2008 - 08:09 PM
A real plug socket will pick up the plug without using a magnet.
  • Ga450owner
Posted August 22, 2008 - 06:56 AM
48-PJ
170-MJ
what needle is this?
  • Mike Martel
Posted August 22, 2008 - 11:57 AM
i got a spark tool that came with the bike that works perfect, you got to take the tank off though.
  • Hot  38 replies
  • 0 replies
  • Hot  50 replies
