CRF 450 Sprocket Size
22 replies to this topic
  • jreutzel
Posted August 21, 2008 - 10:55 AM
I have a 2006 CRF 450. I need to replace the chain and sprockets.
I want to make the bike more trail friendly. I ride a lot of tight single track through the woods in Utah. I am thinking of going 13 on front and 51 on back. Does anybody have any thoughts on this?
Also, if i change the sprocket size, do I need to change from the stock chain length?
I appreciate any thoughts or feedback. Thanks.
  • hondacrf150f1
Posted August 21, 2008 - 11:02 AM
well whats your current gearing? If you are going up a lot in the rear you will proble need to add links to the chain. You may be able to get away with adding 2-3 teeth to the rear if the wheel is already adjusted all the way forward.
  • wantmorepower
Posted August 21, 2008 - 11:23 AM
13/50 should be stock. Depending on what you have on there now, you may be able to live with the chain you have. Its much easier to take links off then to put them back on, so be careful
  • crf-f crf-r trx cbr
Posted August 21, 2008 - 11:54 AM
what ever size you get go for an ironman front and rear with a d.i.d. 520vm x-ring chain......this comba will outlast your bike!.......114 works with 13front-48,49,50,51 no problem
  • wantmorepower
Posted August 21, 2008 - 01:06 PM
what he said +1
  • NorCalRider
Posted August 21, 2008 - 01:15 PM
If you have an '06, 13/48 is stock gearing.
I am running 13/51 for trail riding, works pretty good.
Stock chain length will work fine.
  • FTUO
Posted August 21, 2008 - 02:50 PM
02'-03' are the only years they used a 50.
  • Grazah450
Posted October 13, 2008 - 03:12 AM
wat sort of riding do u do? i have an 06 crf450 and i bush ride a lot. i am finding myself running out of legs on the straights so im wondering Wat i should go with to get a bit of extra speed without loosing to much of the wheelie capability.
  • Dmtalon
Posted October 14, 2008 - 07:16 AM
I got a "kit" made up on ebay from Patrick Lytle. Steel front/rear sprockets and an DID o-ring chain.
I've actually bought a few things from him on ebay and have been completely satisfied. I think that I should of gone with at least a 51T rear or a 12T front as I still think the bike ('06 CRF450R) is still geared too tall for tight woods riding. If you email him and tell him what you want he can make up a kit for you.. You can find him ebay http://myworld.ebay....tleracinggroup/
I don't know this guy personally or have any affiliation. I've just gotten decent service / prices.
Patrick Lytle
info@lytleracinggroup.com
Qty Item ID Description Amount
1 JT28413 JT CS SPROCKET 13T 12.00
1 JT21050 JT REAR SPROCKET 50T 25.00
1 DID520VT120 DID VT ENDURO O-RING CHAIN 120 LINKS 99.00
Subtotal: $136.00
  • 2strokes_rule
Posted October 14, 2008 - 10:38 AM
I run Steel Sunstars 13/52 and a 116 link DID Oring chain.
  • ljschnel
Posted October 15, 2008 - 08:19 AM
Sunstar 50T for me, mostly woods. DID x-ring chain too...
Posted October 15, 2008 - 08:23 AM
always had great luck with sunstars......best alum sprocket out there imho.......did x-ring forever
  • harrysmith500
Posted March 31, 2009 - 09:19 PM
i think Im going to do 13 51.... pro taper rear, and stock front
  • bfair
Posted April 02, 2009 - 10:46 AM
I run an 06 with 13 - 52 and did not have to add a link. Watch your rear chain guide though for clearance. I have an aftermarket chain guide that fits fine but am uncertain about stock.
We ride single track steep hills. I can start on a steep hill and lug around 1700RPM (tach/hour meter) without problems. I do have an 11 oz flywheel which helps.
52 is tall, 51 would be perfect if you don't find yourself starting off on a cliff.
  • rickwood
Posted April 02, 2009 - 12:55 PM
I've got an '02, so my stock gearing was 13/50. Last year I ran 13/53 for trails. It worked well. For dunes, I ran 13/50, but three teeth difference is pushing it without needing more/less chain links. This year I've gone to 12/50 for trails and added a 33 oz flywheel. It works very well. Two side effects are reduced top speed (wasn't too bad at 13/53, but definitely noticable at 12/50) and it's harder to pull a wheelie now (likely due to the flywheel). But it is now very trail friendly based on a week's riding in Moab.
  • harrysmith500
Posted April 02, 2009 - 10:30 PM
where do i get that after market chain guard that will accomodate a 53 tooth sprocket?
  • harrysmith500
Posted April 03, 2009 - 06:34 AM
ttt please
  • bomax
Posted April 03, 2009 - 08:04 PM
i run the 13/50 witha did vt2 ,sunline sl1 sprockets on the rear,lasts along time.
  • CamP
Posted April 03, 2009 - 09:28 PM
TM Designworks makes a chain guide that can handle a 53.
  • harrysmith500
Posted April 03, 2009 - 10:29 PM
Ty!!!
2002 crf450r..Am I wasting my money rebuilding it? by Jonridesacrf
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  47 replies
First real bike, need help. Husqvarna 450 or CRF 450 by zander
  • 3 replies
New woods machine by agreb12
  • Hot  24 replies
2017 crf450 Dyno tuning by moto867
  • Hot  39 replies
2008 CRF450r JB Weld on Crankcase by Sternzy
  • Hot  70 replies
