Wr-450f Motard '06
13 replies to this topic
  • DI MEOLA
Posted August 20, 2008 - 06:27 AM
THIS IS MY 'O6 WR-450 ALL TARDED OUT WITH TRAIL-TECH DASH AND MODIFIED FRONT FENDER, ENDURO REAR FENDER. 320mm FRONT DISC AND 4-POT CALIPER(MOTO-MASTER) WITH DUCATI MASTER CYLINDER AND A BRAIDED HOSE.(MOTO-MASTER) MICHELIN PILOT POWER'S.. FRONT FORKS RE-VALVED AND SHIMMED.
AIR-BOX SNORKEL REMOVED,DRILLED SIDE-COVER AND CURRENTLY BEING JETTED. ZORST IS FROM A YZ SHORTENED 100mm AND RE-PACKED. IT HAS EXCEL WHEELS LACED WITH HAAN HUBS. GEARING IS 14T 40T WHICH POWER'S UP IN 4TH AND HAS SEEN 180KM/H ON THE TRAIL TECH.
...WAIT FOR PIC!
  • Dube2
Posted August 20, 2008 - 11:12 AM
lets see some pics...........
  • roushxteam199
Posted August 21, 2008 - 03:56 PM
ya i have my 03 sumo to. most of the same parts.
heres mine
  • tweav
Posted August 21, 2008 - 04:44 PM
heres mine
Nice brake . how much better is it then just a 320 rotor?
  • roushxteam199
Posted August 21, 2008 - 05:19 PM
well i believe if i tried hard enough i can do front flips. the 4 pistion caliper is amazing.
  • tweav
Posted August 21, 2008 - 09:10 PM
did you respring the forks on yours .I think I'm going to do mine , it nose dives a bit too hard for my taste . Mine feels very mushy in a stoppie.
that is the stock master right?
  • roushxteam199
Posted August 22, 2008 - 01:23 PM
ya its all stock suspension. i dont really see my self spending any more money her. she has already cost me alot. Yes stock suspension and master.
  • DI MEOLA
Posted August 28, 2008 - 11:54 AM
run a higher grade oil in the forks and adjust the spring-rate on the shock to be harder (for your weight) this is a good compromise and prevents your arms leaving their sockets every time you brake and the rear end "squatting" under accelaration, wheelies much easier too! (more rigid rear)
  • DI MEOLA
Posted August 28, 2008 - 11:55 AM
doesn'tyours wanna fall over with the stock side-stand? i had to "chop" mine!
  • tweav
Posted August 28, 2008 - 12:57 PM
I cut down my kick stand on my 07
  • roushxteam199
Posted August 29, 2008 - 04:58 PM
i need to cut mine. thats a winter project. what are you guys running for sprokets. i need to change mine asap. i was thinking 15 45.
  • Thumper_Bloke
Posted August 29, 2008 - 09:02 PM
...WAIT FOR PIC!
Where's your pic, bro? :thumbsup:
  • tweav
Posted August 29, 2008 - 09:06 PM
the gearing really depends what your doing with your bike . I was running a 15/43 gearing but now I've switch to a 13/43. I found I did not need to go much over 100 mph . running the 15/43 I noticed that I shifted into 5th at 90 mph . for highways the 15/43 was a bit better . but most 450 sm bikes on the track will never see 90.
  • roushxteam199
Posted August 30, 2008 - 05:23 AM
im picking up some sprokets today. i just want to beable to cruise at like 70
