06 yz450f wont idle without choke on
11 replies to this topic
  • jic1181
Posted August 19, 2008 - 07:24 PM
I have a 2006 yz450f, have good spark, good fuel. TPS checked good, coil good, bike is stock jetting. Carb cleaned, jets all cleaned. No air leaks. Bike will only run with the choke on, as soon as choke is pushed off bikes dies immediatly. The only thing left is the stator, was told by other people that could be the culpret? Out of ideas, anyone happen to know what the output should be to check to see if its bad or not? Any info would help or has anyone had this problem. thanks
Posted August 19, 2008 - 07:37 PM
There is no electrical problem. It's your idle (pilot) circuit in the carb. It is still plugged up somewhere. Check the pilot jet, pilot air jet, all the passageways, and the idle discharge port in the throat of the carb.
  • jic1181
Posted August 19, 2008 - 07:45 PM
I cleaned it again, checked it light coming through, tried a carb off a 03 450 and the same thing happens, thats why im leaning another way than the carb
Posted August 19, 2008 - 07:50 PM
How old is the gas?
  • jic1181
Posted August 19, 2008 - 07:56 PM
the carb was brand new, never ridden in dirt, or outside
  • jic1181
brand new gas
  • bigred455
Posted August 19, 2008 - 07:58 PM
The hot start is closed correct? When you turn the idle knob in the idle doesn't rise?
  • jic1181
Posted August 19, 2008 - 08:24 PM
idle will rise, siliconend the hot start just make sure it is sealed, seems to be working correctly, sprayed starting fluid no change in idle
  • jic1181
Posted August 19, 2008 - 08:25 PM
i mean no change in idle with choke on with starting fluid
  • desert-rat660
Posted August 19, 2008 - 08:41 PM
i had the same problem, my fuel screw fell out of the carb
  • WB450
Posted August 20, 2008 - 11:38 AM
  • desert-rat660
Posted August 20, 2008 - 04:38 PM
u have that problem?
  • 0 replies
  • Hot  33 replies
  • Hot  106 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 9 replies
