is it really needed or necessary
5 replies to this topic
  • minty0_10
Posted August 19, 2008 - 12:16 PM
today while servicing my wr 450 i thought i,d check the wire gauze that fit into the fram just below the frame drain plug.
well it was a pig to get out i guess i did it the hard way i,l know better next time :thumbsup:
that's if i need to because i ended up braking it.
do the question is do i really need it in place?
i change the oil and filter every to rides so the oils always clean
Posted August 19, 2008 - 12:29 PM
On my steel framed bikes I only removed and cleaned that strainer the first two oil changes on a new bike, after that I left it alone because yes, they break:foul:
It designed obviously to catch big stuff, I typically would find blue paint chips :thumbsup: but noting after the second time I removed it...
  • dazzabb
Posted August 20, 2008 - 03:34 AM
I've never removed it and I don't worry about it.
Must have done 10+ oil / filter changes and it still remains in the same position as when I bought the bike.
  • matt4x4
Posted August 20, 2008 - 04:07 AM
removed mine once - was perfectly clean - pretty much forgot it existed now.
  • farkawi
Posted August 20, 2008 - 04:15 AM
They put the same setup on the old tt500s. I still have several of them and only look at them when doing a buildup or removing an engine from the chassis. I looked at the one on my 05 wr 450 at the second oil change and found no big chunks. That filter will now stay in place until I need to do an out-of-frame engine overhaul.
Just for the record, the WR450 is everything the old TT/XT 500s should have been. It's still a bit porky for all day trail weightlifting but the power is bountiful and the bike is dependable. The E-start is an older rider's ticket to nirvana.
  • face_plant
Posted August 21, 2008 - 07:10 AM
first 2 oil changes also
found i wasted my time
