question on internals of stock forks?
1 reply to this topic
  • skibum_1260
Posted August 18, 2008 - 07:36 PM
got a 01 yz426 that i know the front end has been lowered and im replacing the seals i figured i might as well take it back to stock as i could use the extra ground clearance since im really gettin tired of getting hung up on trees, i know the springs are shorter then stock for sure so those are getting replaced with a extra set of stock ones i had lying around, but i also pulled the damper rod assembly apart where just above the shim stack was the normal spring(bottoming spring or somethin i think its called) then i would say a 2" nylon orange spacer, im assuming this is to limit the free length of the fork correct? i will need to remove this to get my full travel again correct? i would post a pick but my cameras broke, and tried finding it on some parts schmatics but aparently were not suppose to go this deep into out front end?! thank in advance.
Posted August 18, 2008 - 09:34 PM
Without seeing it, I'd say you were correct. You can check here:
http://www.thumperta...isplay.php?f=47
Someone will know for sure.
  • Hot  113 replies
  • Hot  47 replies
  • On January 15, 2017
