Seal question
6 replies to this topic
  • dirtbiker450f
Posted August 12, 2008 - 11:30 AM
Another Question. I have an 05 YZ450F and I just put a brand new seal in the case after splitting them to put a crank in it. The seal did not leak before I split the cases but the new one does. I drove the seal in as far as it would go and im thinking that it's leaking because it is in too far. I looked at my bro's yz250f and his seal is flush with the case and mine is in further than that. So what i'm asking is whether the seal is supposed to be flush with the case or is it supposed to be in further?
Thanks,
Ryan
Posted August 12, 2008 - 04:35 PM
What seal are we working on?
  • dirtbiker450f
Posted August 12, 2008 - 06:21 PM
The oil seal around the sprocket shaft.
Posted August 12, 2008 - 06:44 PM
That seal depends on the condition of the sleeve it runs on. If the collar is deeply grooved, the seal will not hold. There is also an O-ring under the collar that seals it to the output shaft.
  • dirtbiker450f
Posted August 12, 2008 - 07:02 PM
The o-ring is brand new and the sleeve is not grooved. I just need to know whether to drive the seal in flush with the case or further than that.
Posted August 12, 2008 - 07:30 PM
Flush.
  • desert-rat660
Posted August 12, 2008 - 09:08 PM
make sure u clean the mating surfaces really good or u can get a leak again
  • Hot  36 replies
  • Hot  47 replies
  • Hot  38 replies
