Cleaning alloy frame
5 replies to this topic
  • Strattos
Posted August 12, 2008 - 03:23 PM
How are you guys with alloy-framed WRs keeping the frame clean where your boots rub on it?
I've done searches of these forums using 'clean alloy frame', 'alloy frame clean' but haven't found an answer.
What i'm concerned about is using a solvent which could stain the alloy. Any suggestions?
  • KJ790
Posted August 12, 2008 - 03:28 PM
I use SOS pads from the grocery store. Not sure what they are called down under, but they are the steel wool pads with special soap inside intended for cleaning and polishing pots and pans. These bring the frame back to the original look.
PS: Try a search using "aluminum" instead of "alloy".
  • William1
Posted August 12, 2008 - 05:15 PM
I use "Never Dull".
You can get it at most hardware stores.
  • suzukipoo
Posted August 13, 2008 - 01:15 AM
I use ali-bright!!
  • Island Boy
Posted August 13, 2008 - 12:47 PM
WD40, a scotch pad and some elbow grease works best.
  • Strattos
Posted August 14, 2008 - 03:39 PM
Magic thanks guys. I'm off to start scrubbing
