no spark
20 replies to this topic
  • jeredlee
Posted August 11, 2008 - 08:51 PM
i have a 2004 yz 450 im not getting any spark. i put a new plug and coil timing is good and still nothing.i went through the eletrical system and it all looks good im stumped:confused: .any help would be awsome
  • desert-rat660
Posted August 11, 2008 - 08:57 PM
did u check the grounds? cdi unit?
  • desert-rat660
Posted August 11, 2008 - 09:04 PM
also check the kill switch, ive seen problems with them, a simple way to check it if u dont have an ohm meter is to unplug it. then see if u get spark
  • jeredlee
Posted August 11, 2008 - 09:13 PM
i have checked the kill switch and its good ill check the ground. were is the ground
  • desert-rat660
Posted August 11, 2008 - 10:02 PM
close to the cdi unit
  • bigred455
Posted August 12, 2008 - 06:40 AM
Just unmount the kill switch and see if you get fire.
  • jeredlee
Posted August 12, 2008 - 10:56 AM
ok thanks ill try both and let you guys know
  • jeredlee
Posted August 12, 2008 - 07:07 PM
unpluged the kill switch and still no spark .didnt find the ground for the cdi box.do you guys think the cdi box could be bad is there a way to check that
  • desert-rat660
Posted August 12, 2008 - 09:03 PM
easiest way is too swap it. is your pickup coil good?
  • shortburb
Posted August 13, 2008 - 05:15 AM
CDIs are not a common item to go bad.
Pull the ignition cover and check the flywheel/pickup.
My flywheel came apart and gave me a no spark symptom because the pickup ridge (I dont know what its really called) was no longer passing by the pickup therefore not initiating spark.
  • jeredlee
Posted August 13, 2008 - 09:28 AM
how do you check the pick up coil
  • desert-rat660
Posted August 13, 2008 - 04:26 PM
u can ohm it out with a multimeter
  • rideout743
Posted August 28, 2008 - 07:48 AM
mine done the same thing! it is brokein now and i cant fegger out what is on the go!
i have a 04 yamaha yz450f and the other day it stoped working, it had no
spark from the spark plug so i got a new plug and now it has a good plug in it and it still wont start. i cant kick it over it wont start, i
cant pick it up by toeing it behind my dads truck. it has loads of compretion and i checked the timeimg chain and
stator and it is all good. when i to toe it behind dads truck it makes this low sound and is almost like
it wont take aney gass cause it dont realy move. aneyone have aney advice? i am realy stumped... :thumbsup::worthy:
  • jeredlee
Posted September 02, 2008 - 09:08 AM
i still cant find out whats wrong i think i might have to take it to the shop
  • desert-rat660
Posted September 02, 2008 - 10:33 AM
try disconnected the kill switch, if it fires up then u know the kill switch is bad
  • arnego2
Posted September 09, 2008 - 03:57 PM
Hi there
mine, a 2006 YZ450F went out quitely and after changing the plug without results we checked the stator which gives off energy so there are only a few items remaining. The CDI or the ignition coil, well the wiring too I suppose.
Lets hope that tomorrow I know more.
regards
Arnego2
  • arnego2
Posted September 10, 2008 - 03:05 PM
Hello there
In my case it was the stator, well at least they have it here in the country. Soon I can :thumbsup: again on the YZ450F
regards
Arnego2
  • jeredlee
Posted September 11, 2008 - 12:30 AM
what is the stator and were is it at i looked in manual and didnt see anything called that:confused:
  • arnego2
Posted September 11, 2008 - 05:00 AM
Hello
here you can see one: Posted Image its below the oil fill screw.
M-f-G
Arnego2
Posted September 11, 2008 - 05:20 AM
The manual refers to it as the magneto. Test is on page 6-8.
  • Hot  30 replies
  • 0 replies
  • 10 replies
  • On January 15, 2017
