Clutch Lever Adjustment
1 reply to this topic
  • 4xsama
Posted August 11, 2008 - 12:14 AM
Hi,
I'v recently bought an '06 WR450F and after a few outings on the trails have started to make some adjustments like tilting the bars forward a bit, lifting the gear shifter and moving clutch and brake pedals inward a bit.
All is good except for the clutch. I now can use two fingers on the brake and want to do the same on the clutch.
What sort of adjustment can I do. Is it possible to adjust for reach and can the travel be shortened up a bit. Or, due to the weight of pull required am I kidding myself and a two finger pull is gonna kill.
Cheers
  • maxtherat
Posted August 11, 2008 - 05:12 PM
Buying shortie levers may help or buy a whole new perch with a cr style lever. Not sure but, ASV levers may have an adjustment for reach.
