YZ450F Idle problem
2 replies to this topic
  • locorider
Posted August 09, 2008 - 06:03 PM
Hi there. I am sure you guys on here will square me away pronto.
Here is the problem.
I have a 2004 YZ450F. Bought it a month ago.
If I increase the idle, by turning the idle screw, it goes up for a couple of seconds, then drops down to a slow idle again. If I blip the throttle it sits at the higher idle foe about 5 seconds then drops down again.
Any ideas ?
Posted August 09, 2008 - 08:22 PM
This is a "hanging idle". It's normally a lean condition. Start by checking for obvious air leaks, then get the idle mixture set right. If that doesn't do it, check the valve clearance.
  • bigred455
Posted August 09, 2008 - 08:50 PM
I also would set the fuel screw come out richer,but sometimes if you put the idle a hair too high it hangs.Try lowering the idle after the motor is totally WARMED UP , and then try it.
