08 wr450f hard starting
9 replies to this topic
  • Pine Nutt
Posted August 09, 2008 - 05:59 PM
Help! I have put in all the INDY suggested jets and have had great results :D
But I still have one problem its hard to start cold or hot it takes 4-5 or more cranks on the stater to get it going not till after it pops (Backfires)and starts
It has been this way since I got it brand new and did all the fixes to make it run more than 1/2 throttle. Ais, grey, wire, ect:But its still hard to start
any suggestions anyone :)
  • RFausel
Posted August 09, 2008 - 06:08 PM
Did u try to change the starter jet?
  • JSanfilippo
Posted August 09, 2008 - 10:08 PM
With the e-start or kick.
My bike takes ten revoulutions of the starter to start cold. It'll start in one kick under the same circumstances :)
  • William1
Posted August 10, 2008 - 07:28 AM
Not sure if you checked this, but when I got my WR, it was a pain to start too. I pulled the plug and found the gap was set way to large. Once properly set, starting was much easier.
I also found a larger starter jet (was a 68, went to a 72) kept the bike running instead of 'start, run for a second, stall, restart, run for a second, stall, restart, finally keep running).
  • Pine Nutt
Posted August 10, 2008 - 07:40 AM
Change To What ? It's stock now think 65 :)
  • Pine Nutt
Posted August 10, 2008 - 07:48 AM
E-start! Mine is the same way! starts in 1 kick when warm starter takes 5-10.
I bought the wr for the e-start to get off the line faster but its not working out that way :D
  • William1
Posted August 10, 2008 - 09:06 AM
Mine e-starts instantaneously now....
  • Pine Nutt
Posted August 10, 2008 - 12:30 PM
Thanks going to see if I can find a bigger # start jet.
Have to try anything.
  • William1
Posted August 10, 2008 - 12:43 PM
You did confirm the plug was gapped properly, right? The larger starter jet only makes it stay running on cold start.
I know Carb Parts Warehouse has them, they ordered them by mistake and normally do not stock them.
  • Strattos
Posted August 10, 2008 - 02:12 PM
For those having trouble starting a warm/hot engine, are you using the hot start?
I've only recently upgraded from a 426 and was having trouble starting a warm engine (not necessarily a really hot engine in summer or after a fall) and went back to the manual to check the basics and it does say to use the hot start on a 'warm' engine.
Coming from the 426 I thought the hot start was only used after a fall or when the motor was really hot. Ever since using the hot start my 08 WR it starts really easily using the button.
