Oil filter drain hole diameter & depth
11 replies to this topic
  • AZ Thumpdaddy
Posted August 09, 2008 - 03:58 AM
All,
I have a new 07 450 and haven't been able to ride it as it is too hot, so no oil change yet. I have been reading all the threads on the oil filter draiin hole and the thread damage issues to the hole from metal particles. I really like Gray's fix with the ball bearing or hole block fix. I was considering having an aluminum press fit plug (silghtly tapered) machined to size and was wondering if anyone has measured the hole diameter with a gage pin and know the exact size of it? Also, what would be the recommended depth of the plug before it starts entering the threaded area? I can measure it myself , but if someone has already done it then it will save some time.
Gray - do you know? Does this sound like a reasonable fix?
T-Daddy
Posted August 09, 2008 - 03:40 PM
I believe the hole is 3mm to begin with, but I didn't gauge it exactly. Your fix is reasonable enough except for all the work the goes into machining a plug for the job when it's so easy to get 3/16" balls. I see no advantage to making a plug for the purpose. :)
  • desert-rat660
Posted August 21, 2008 - 09:01 AM
i did the ball trick like u last nite, i had an old 3/8 extension i drilled a hole in the back of it to get the ball out,i went to tap it into the hole and accidently dropped it down the oil feed hole which i should have plugged up:banghead:
needless to say i had to turn the bike upside down to get the ball out. but the ball worked great, i just tapped it right into the hole.
Good thinking Gray:applause:
Posted August 21, 2008 - 09:28 AM
... i had to turn the bike upside down to get the ball out.
:D :doh: :worthy: :blah: Oh, now there's a mental picture for you. :thumbsup:
Thanks for the laugh. :busted:
  • bigred455
Posted August 21, 2008 - 09:52 AM
Your heart must have dropped when the ball dropped.:thumbsup:
I plugged my oil filter drain hole with a piece of 6 gauge copprer wire cut into a small piece.I grinded down the tip so it would fit the hole but the rest of the piece is tapered thicker. Then I got a screwdriver the handle end and packed it in nice and tight. 5 rides did not budge. Neither of our methods it will not come loose,even if it did from the oil pressure,the filter will stop it from going any farther. I changed the filter twice after the plugging,the bolt has never been soooooo smooth threading in.
  • desert-rat660
Posted August 21, 2008 - 10:04 AM
ya second time around i plugged it with a q-tip, but its in there now.
  • bigred455
Posted August 21, 2008 - 10:13 AM
I am thinking if you didn't get it out,which by the way very lucky:thumbsup: .That hole to the right where the ball was dropped , oil feeds into the well.If the motor was started for a couple seconds,I would think the ball would have came out with pressure from the pump.Regardless GOOD SHOW!:thumbsup:
Posted August 21, 2008 - 10:24 AM
Unless it rolled into the oil pump an broke it when you tried to turn the engine over. :thumbsup: :worthy:
  • desert-rat660
Posted August 21, 2008 - 10:31 AM
exactly why i wasnt going to start it.
  • bigred455
Posted August 21, 2008 - 10:53 AM
Surely that could happen,but I would think it would have stopped before totally hitting the pump gear. Taking the inner clutch case off would be the correct and safe way.
Posted August 21, 2008 - 11:43 AM
Then again, if you turn the bike over and it rolls out on the floor, why not? (still laughing) :thumbsup:
  • desert-rat660
Posted August 21, 2008 - 12:57 PM
exactly!! i would have to replace the case gasket and such, i took the gas tank off and dumped it on its lid, out it rolled. didnt take over 5 minutes!!!
  • Hot  28 replies
  • 10 replies
  • 5 replies
  • On January 15, 2017
1998 yz400f will not idle. by trolley
  • Hot  32 replies
