2008 450 spring rate questions
3 replies to this topic
  • davbrucas
Posted August 08, 2008 - 03:00 PM
Just came back to Yamaha after several years on Hondas. What spring rates are recommended for 190lb MX Vet B? I ran 0.48/5.6 on the 07 CRF450. Will the 06 YZF450 fork springs work on the 08? Thanks.
  • TimFurryBalls
Posted August 08, 2008 - 04:52 PM
Heh, heh. Welcome back. So I have I. . . .
Posted August 08, 2008 - 05:17 PM
The stock rates (0.47 kg/mm fork and 5.3 kg/mm shock) should be just fine. If the courses you ride are more in the Supercross category, .48's and a 5.4 or 5.5 might be better. The '06 springs will fit.
  • VB_Racing
Posted August 08, 2008 - 05:35 PM
I'm the same weight as you and run stock springs on my 08. I'm a decent B rider. I have no problems after adjusting clickers and sag.
Dave
  • Hot  36 replies
Motocross
  • Hot  491 replies
  • 9 replies
