06 450 idle probs
2 replies to this topic
  • metalmulisha
Posted August 05, 2008 - 01:22 AM
hi guys just recently pulled off the carby for a good clean and installed the the r&d power pump with adj leak jet and stiffer spring for the ap linkage, and also a r&d flex mixture screw but now notice that the idle hangs slightly any ideas??
thanks
  • desert-rat660
Posted August 06, 2008 - 08:52 PM
check the throttle cables, make sure they are moving free and have some slack
  • _JoNeS_
Posted August 07, 2008 - 11:39 AM
maybe running too lean, problems with the TPS, air leak, slider might be sticking slightly (but probably not if you've cleaned all the carb properly).
  • 10 replies
  • Hot  30 replies
