Has anyone done this? wr450
4 replies to this topic
  • skisnh
Posted August 04, 2008 - 04:13 AM
While I was installing my Vapor computer (love it) I removed the headlight assembly to get access. I noticed the WR came with a hi/low bulb. I removed the pin from the low beam side and moved it to the empty high beam terminal. I like the extra light..my question is if I ride slow tight single track all day does the stator have enough juice that it wont drain down my battery? has anyone else done this?
  • Alternative
Posted August 04, 2008 - 05:08 AM
The high beam of the bulb is probably the same or only slightly more wattage than the low beam (probably a 35/35W or 55/60W) so you're not drawing much more current, if any. So no, you won't drain your battery.
  • ophir
Posted August 04, 2008 - 07:51 AM
I have them both hooked up with a switch so that I can run either hi or low.
  • TooFast
Posted August 04, 2008 - 10:29 AM
Your headlight is actually running on AC, not the battery DC
  • skisnh
Posted August 04, 2008 - 05:49 PM
Thanks for the replies..:ride:
