02 WR426 Excessive Blow-By out of Head Vent Tube
No replies to this topic
  • muzzym
Posted August 03, 2008 - 12:03 PM
I have an 02 WR426. Runs strong. I rode fairly hard in hot weather
a few weeks back and noticed oil dripping (quickly) from the head vent tube.
After further inspection, I noticed that there is a pretty good flow
of air pressure blowing out of this vent tube when running.
Do you think this pressure (blow by) is being generated by a broken oil ring
or head gasket? If I unscrew the oil filler cap while running, oil will
almost pump out of the filler tube (again it seems to be pretty well pressurized)
The only reason I really noticed this is that I checked the oil before riding today and it was very low. (should not have been) Additionally, it has what seems to be a lean bog (will stall engine) if throttle is cracked quickly)
None of this (leaking oil or bogging) was happening prior tp my last ride. Pretty sure I broke something, just looking for some second opions.
Any help is appreciated. :ride:
