2006 yz450f died without any reason...
5 replies to this topic
  • gerardlane
Posted August 03, 2008 - 10:33 AM
Hey all, My yammy has called it quits today. Shes got about 70 hours only 15 on the high compression piston. I stalled her in a corner and from then on she wouldnt start. There was plenty of compression when i kicked 'er... Ill have to tear her apart tommorow and check for spark but has anyone had this happen I checked for fuel too, there was plenty.... thanks
  • cowboyona426
Posted August 03, 2008 - 05:19 PM
My first thought is to check the timing. Second thought is bad coil or problem with the stator not supplying power to the coil.
  • Family Man
Posted August 03, 2008 - 05:51 PM
The spark plug may have fouled. I know its rare with four stokes but I would start there.
  • skthom2320
Posted August 04, 2008 - 06:53 AM
I once had the slide disengage from the actuator (the small philips screw fell out) and kill the bike over a jump! It just died and no amount of kicking would restart it.
I did what everyone should do when the bike won't run...
1. check for fuel
2. check for spark
3. check for air
When I took the carb off to investigate and make sure it was getting fuel from the gas tank to the cylinder, I heard the rattling!
Check everything!
  • cowboyona426
Posted August 04, 2008 - 08:45 AM
1. check for fuel
2. check for spark
3. check for air
Check everything!
That must have been on one of your pink bikes... would never happen on a Yamaha :ride:
  • skthom2320
Posted August 06, 2008 - 11:07 AM
That must have been on one of your pink bikes... would never happen on a Yamaha :)
Nope. The pink bikes have only had plugged up pilots and lost fuel screws.
The blue bike was the culprit. And it was over a jump!!!! I landed without the engine running and the clutch pulled in. Even though I was prepared for it I still kissed the front fender and did a nice flying W. Then I rolled off to the side and went - "WTH???
  • Hot  30 replies
  • Hot  50 replies
  • 10 replies
  • 5 replies
