YZ450 19" rim help
7 replies to this topic
  • Mrmonk7663
Posted August 02, 2008 - 07:40 PM
Hey everyone. Do any of yall know if the rear 19" rim/hub from a YZ450 will bolt up to the FRONT of a WR450? I have an 04. I'm doing a budget supermoto project, and no I don't want to just save up for 17" rims. I think 18 in the rear and 19 in the front will work just fine. Any help with a suitable rim would be much appreciated. I would rather find a rim/hub instead of buying a wheel and having it laced to my hub.
Thanks alot,
  • jhmotard
Posted August 02, 2008 - 09:50 PM
just buy the Kenda K761 sportsman tires....cheap too
  • Mrmonk7663
Posted August 02, 2008 - 11:52 PM
While that is an option, I like the look of the smaller rims/tires and I also would benefit from the shorter rim/tire as it would lower the bike a bit, which I desperately need. Does anyone know of any 18 or 19 inch rim/hub from a stock bike that will fit on the front of a WR450? Thanks
  • Mrmonk7663
Posted August 03, 2008 - 11:22 AM
If there is no available bolt on wheel/hub assembly...what about hubs. What hub will will simply bolt in place of my stock hub on this bike? Where can I source one from. A new factory hub can be had for $125 but i'm on a budget. A Complete wheel/hub would be better but I don't know if there is one out there. Anyone?
  • jhmotard
Posted August 03, 2008 - 09:57 PM
or you could spend a little extra for 17" hoops and spokes for your stock hubs...depending if you want to keep your dirt setup intact...
  • Mrmonk7663
Posted August 04, 2008 - 06:15 AM
Ok let me ask this. Is there a big advantage to running aftermarket hubs vs stock hubs? What is the low down on this. I know some hubs are really light weight but will stock hubs be just fine?
  • Alternative
Posted August 05, 2008 - 03:29 AM
Yes stock hubs will be fine. Most of the aftermarket hubs are actually heavier than stock ones so there's no real advantage, other than looks.
  • Mrmonk7663
Posted August 05, 2008 - 07:51 AM
Thanks, thats what I needed to know.
