Dr.D exhaust and radiator lowering kit
20 replies to this topic
  • YZ450RDR
Posted August 01, 2008 - 06:36 AM
Looking to upgrade my exhaust on my stock 08' YZ450F. The Dr.D Ti exhaust with the radiator lowering kit good choice? Does lowering the radiator really help cornering? The FMF 4.1 w/megabomb another choice? What other mods would you recommend? Thanks for your input.
  • cowboyona426
Posted August 01, 2008 - 06:53 AM
I have the Dr. D stainless system without the lowering kit (you need a different header with the lowering kit) and I like what it does for the bike.
Posted August 01, 2008 - 07:15 AM
As far as I know, all current RDR exhausts come with the header that is compatible with the lowering kits. Mine did, and I did not specify that I wanted it.
Other mods: bars that suit you, mounted as far forward as practical, and a good strong chain to replace the one that came with it before it destroys the sprockets. The bike needs nothing else unless you weigh more or less than 170-195.
  • Justin89
Posted August 01, 2008 - 10:45 AM
I personally like the 4.1/megabomb combo but I've heard nothing buy good things about the DR D...if you get the lowering kit, post soemthing on how you like it...I wanna get that too:busted: MXA seemed to raive about the lowering kit so it's prolly worth a try
  • KJ790
Posted August 01, 2008 - 12:02 PM
The FMF factory forward powerbomb (different than the standard powerbomb) also is compatible with the Dr. D radiator lowering kit. I run this with a factory 4.1 silencer on my 450 and actually like it the best of any exhaust I have tested. Along with this set up I have had an MX powerbomb, an SX powerbomb, a megabomb, and a Dr. D system for my 450, and this is what I stuck with. The Dr. D was my second favorite. On my 250F I liked the megabomb the best.
  • cowboyona426
Posted August 01, 2008 - 12:13 PM
When I ordered mine spring 07 I thought they told me that a different header was needed. They also told me that it would clear my oil filter cover, which is not the case. Good to know that if I ever do decide to try the lowering kit my current header is probably fine.
Posted August 01, 2008 - 01:28 PM
You can fix that. I had to custom make one out of a longer bolt, but if you replace the forward filter cover bolt with a stud and a nut, you can slip the cover off without bothering the header.
  • cowboyona426
Posted August 01, 2008 - 01:50 PM
How do you come up with all these good ideas? Do tell more... did you just lock-tite the stud into the case so it doesn't thread out when you try to take the nut off?
Posted August 01, 2008 - 03:03 PM
I picked that one up from,...oh yeah, Thumper Talk. :ride: Don't remember from whom, though.
Yes, blue Loc-Tite and tightened it in with a double nut. I use a "star washer" to help ensure it won't fall out.
  • racerxx276
Posted August 02, 2008 - 08:06 AM
finally put a Dr D ti ti on my 08. It replaced my FMF powercore slip on. Lots more low and mid over the FMF. Unfortunately the 08 motor has never had any top end/ rev like the 06 and 07 and the Dr D pipe didn't give it any top end. I'm afraid that if I put the Dr D pipe on my 07 I'll never ride my 08 again... . Will order the lowering kit for it this week.
  • cowboyona426
Posted August 02, 2008 - 07:50 PM
Star washer under the nut I presume?
Posted August 02, 2008 - 07:59 PM
Zackly
  • mxracer206
Posted August 04, 2008 - 04:31 AM
I run a DR.D headpipe and stock 06 muffler on my 08. I have the older style D shaped DR.D and though it runs well it is a little loud, I know the new style exhaust works well and I think is a little more quiet. The 08 really turns a lot better but since I already had the head pipe I put on a lowering kit. I was expecting it to be all bling and no bang but I noticed it on the first corner, it really did help the bike stay down in corners. I also use a stud so you can change the oil filter but use a shouldered lock nut instead.
  • yam 3
Posted August 05, 2008 - 07:16 PM
I found the same to be true...love the lowering kit!
  • CL2D24
Posted August 14, 2008 - 08:36 PM
When you put the stud in did you torque it to what the manual calls for with the bolt?
Posted August 14, 2008 - 08:54 PM
Depends on what you mean, exactly. The stud itself was probably torqued to something a little more than the value called out for the cover, but the nut is run down the same as the other two bolts are.
  • CL2D24
Posted August 14, 2008 - 09:33 PM
Yeah, what I was asking about was how much to torque the stud to.
  • Aka.Goose
Posted August 16, 2008 - 01:18 PM
GR, can't you just open up a yz mod shop?
Please?
  • desert-rat660
Posted August 16, 2008 - 01:42 PM
gray did u use a stover nut with the stud
Posted August 16, 2008 - 04:04 PM
No, because I didn't want the nut to unscrew the stud when I took it off.
