wr450 03'-04' forks, 46mm or 48mm
6 replies to this topic
  • marine89
Posted July 31, 2008 - 06:12 PM
can someone please help me clear this up once and for all? I did a search and everything leads me to believe that the 04' wr is a 48mm but I looked for seals and the seals are listed for 03' and 04' being the same size(46mm), what gives? this all started because I bought some triple clamps for an 03' 04' wr 450 so that i can put them on my 03'yz250 2 stroke which has 46mm forks. I got a killer deal on some brand new triple clamps and now i don't know if i will be able to use them, someone please shed some light on this, thanks....
  • Just_a_trail_rider
Posted July 31, 2008 - 10:33 PM
I am reasonably sure that 2005 was the first year that they put the 48mm forks on the wr's.
  • greengoose999
Posted July 31, 2008 - 10:46 PM
my wr450 03 model has 46mm forks but i have a set of yz450 04model forks on them now and they are 48mm..
  • marine89
Posted August 01, 2008 - 12:45 AM
I know that the 04' yz450 has 48mm but as far as the 04' wr I'm just not sure. any 04' wr owners care to put in their two cents?
  • lixno
Posted August 01, 2008 - 03:35 AM
'03 and '04 WRFs had definitely 46mm forks.
The '05 models had for the first time 48mm forks. (don't confuse the '04 YZFs that got first 48mm forks).
  • ncmountainman
Posted August 01, 2008 - 05:58 AM
correct,03-04 wr forks are the same as 03 yz forks 46mm except for the wr's used a shorter spring and softer shimstacks:thumbsup:
  • marine89
Posted August 01, 2008 - 07:05 PM
thank you all very much.
