Just just a 2001 XR 200 in great shape for only $900! Anyways, since it didn't come with a manual, my questions are: What weight oil does it take, and how much, and can I use 90weight gear oil to lube the chain?
Oil for a 2001 XR 200
Posted 30 July 2008 - 09:33 PM
Posted 31 July 2008 - 05:43 AM
Dwight
Posted 31 July 2008 - 05:08 PM
chukb said:
Just make sure it isn't Castrol GTX but Castrol Motorcycle oil.
GTX will not hold up in a motorcycle and contains friction modifiers.
Dwight
Posted 31 July 2008 - 05:58 PM
Also, how much oil does the engine take, and is the transmission oil shared with the engine?
Posted 31 July 2008 - 06:39 PM
Dwight
Posted 01 August 2008 - 04:48 AM
Dwight_Rudder said:
Dwight
my manual for 03 xr100 says "api class sg or higher except oils labeled as energy conserving on the circular api service label"
I don't have any 10-40 to look at, but the castrol gtx 20-50 I just looked at in my garage doesn't say energy conserving in the circle, but the 5-30 for my car does.......I've always used regular castrol gtx in my 4 strokes with no probs.
sm is rated higher than sg, right?
Posted 01 August 2008 - 11:15 PM
SM is not good for motorcycles . Low in zinc and phosphorus. Friction Modifiers added. Oil does not have to have energy conserving on the label to have friction modifiers.
I have seen many many Honda XRs ( mainly RFVC engines ) fried due to using junky Castrol GTX. Use a Motorcycle specific oil with JASO MA rating. If you can't use Shell Rotella. Closest to a motorcycle oil in automotive oils. DO NOT USE SHELL SYNTHETIC ROTELLA. Possible clutch issues. I had a problem with one of my Honda SL100s when using Synthetic Rotella when I was in a bind.
Dwight
Posted 01 August 2008 - 11:26 PM
Dwight
Shell Rotella is NOT an automotive oil, it is a diesel oil.
There is a huge difference on makeup between the two.
Rotella T 15w-40 contains no friction modifiers.
Posted 03 August 2008 - 03:44 PM
Posted 03 August 2008 - 04:11 PM
dumbdotdog said:
Diesels had have catalytic converts since the late 90s. They now have a particulate filter, which requires low-ash oil, and reduced sulfur levels.
Posted 03 August 2008 - 04:26 PM
Posted 03 August 2008 - 05:13 PM
dumbdotdog said:
Yes, they are reducing the levels of zinc and phosphorous, but it's still within the "safe" range.
Wrong, diesels do not have catalytic convertors-they are getting DPF's, an entirely different animal. Similar in idea, but not function. DPF's are a filtration system that captures soot to be burned at a later time. Cat's OTOH, heat up and "burn" the junk constantly.
Lead Head said:
No, they have not. The few diesel automobiles that have been made do have emissions systems, but once you reach the level of 3/4T trucks, it wasn't required until recently. Medium duty, buses and semi's were not required to have any emissions systems until 10-02 mfgr date.
dumbdotdog said:
Shell Rotella T Multigrade Oil SAE 15W-40 with Triple Protection Technology, our API CJ-4/SM specification product, typically contains about 1200 ppm zinc and 1100 ppm phosphorous as manufactured.
Now, the question is, what is the threshold of zinc and phosphorous needed for proper transmission protection?
There has been some talk and emails passed around that are said to have come from Shell's "Ask the Engineer" that claim that Rotella T with Triple Protection 15W-40 and Rotella T Synthetic 5W-40 CJ-4 do meet JASO MA.
I can't say this is fact, since I didn't inquire myself, nor did I get it from Rotella's site.
Posted 04 August 2008 - 03:37 PM
This link explains a lot about lube oils for motorcycles and makes a good read:
http://motorcycleinf...****/Oils1.html
this is the URL (remove the extra spaces): http://motorcycleinfo. calsci. com/Oils1.html
Posted 04 August 2008 - 04:11 PM
IMO,
Dwight
Posted 04 August 2008 - 06:30 PM
Dwight_Rudder said:
IMO,
Dwight
Exactly, plus its nice to know that small oil companies like Maxima, Bel-Ray etc.., don’t produce auto oils, therefore don’t have to conform to government regulations that apply to automotive oils and have a "free hand" in producing the best oil for your motorcycle.
