Rear axel blocks on 08
3 replies to this topic
  • baymen12
Posted July 28, 2008 - 07:00 PM
The rear axel blocks are not the same size. Which one goes on which side?
Posted July 28, 2008 - 07:44 PM
One has an L shaped lip on one edge, that one goes on the sprocket side, and the L shaped lip goes forward. When using the marks to align the chain, count from the back edge of the block forward, or you'll be one full mark off.
  • j-ripper
Posted July 29, 2008 - 01:29 PM
grayracer,,you rock!!! flat out, i was thinkin i had a bent swingarm cause when i used the notches, the bike rode crooked so i just used a tape from the axle to the swingarm bolt, never knew you had to read them back to front,,thanks
  • bigred455
Posted July 29, 2008 - 02:41 PM
Bet the bike was pulling to the right.If you count from front to back with the notches,the rear tire will favor pointing right.
