Click, Click, Click
2 replies to this topic
  • gratefuldawg
Posted July 28, 2008 - 06:05 AM
We have a 01 426 and after it warms us when you pull in the clutch there is a clicking noise from the right side of the engine. Otherwise no other symptoms. Any ideas?
  • byggd
Posted July 28, 2008 - 08:25 AM
Did it just start making the noise or has it been making it for some time? Either way it doesn't sound good so you may want to lay it over, pull the pin on the brake lever so you can swing it out of the way, remove the cover and take a look in there.
  • matt4x4
Posted July 28, 2008 - 09:47 AM
Probably the bearing that gets pushed by the actuator rod - on cars it's called a throwout bearing...
