Loud Pops & Sputters until motor is Hot?
3 replies to this topic
  • hsstar
Posted December 17, 2002 - 06:09 AM
I Know my bike is cold natured, but something is not right.
Recently started poping and sputtering for the first 10 minutes of riding. I already warm the motor up for a few minutes before hiting the woods. Once the motor gets hotter it runs fine. I never had this problem until a few weeks ago.
I took the carb apart and found no dirt or anything clogged, the float measured in corect at 9mm.
I checked the valves 2 months ago and all was in spec.
I have the WR carb gutted to YZ specs. I dont think I should change any jetting because the motor ran fine for 3 years with the jetting I have.
I tried cr9e and have always run the cr8e. Same popping
Should I hook the grey wire back up?
Could it be muffler packing????
If anybody has had the same problem Please advise me of the cure.
  • Dan_Lorenze
Posted December 17, 2002 - 06:29 AM
Star, Did the bike all of the sudden start doing this or did you pull the carb apart and when you got it back together it started doing this?
  • hsstar
Posted December 17, 2002 - 06:54 AM
All of a sudden.
Pulled carb apart to try and fix.
Thanks for asking.
  • waynewr
Posted December 17, 2002 - 08:04 AM
Just a couple considerations:
Hope your not having valve trouble, that repair is challenging.I know sometime a worn exhaust valve seat can cause this noise as combustion leaks into the header.
Is there a possiblity of bad gas causing pre ignition?
