yz426 00 my tank keeps splitting need help
10 replies to this topic
  • nathanyzf426
Posted July 23, 2008 - 11:01 PM
ok my tank is splitting under neath right down near the air box cant work out y it is doing it i had it welded bak up and it was going gr8 i even forgot bout it for a bit then the next day i went riding and instead of enduro we went out hitting jumps bout 40 footers and i hit it bout three times then i started smelling fuel straight away i knew it split agen put my finger up under there and it was worse then ever wat should i do or how can i stop it i been quoted for brand new tank 600 bukks really dun wanna pay that aye it is in the shop getting welded bak up but i just wanna know wat could be causing this to happin its a clean split i thought maybe something had hit it but it hasnt no gouges no nothing just a cleen split ;) :ride: any information would be appreciated and also i aint ever heard of a tank splitting in my life nor has my mates really need to get this sorted out asap spose to be riding this weekend its now thursday night days are running out thanks heaps nathan:banghead:
  • thumpin2
Posted July 23, 2008 - 11:09 PM
Ebay!
  • nathanyzf426
Posted July 23, 2008 - 11:16 PM
Ebay!
mate i have had a look as i said i would like to know wat is causing the problem not just keep replacing tanks cheers
  • matt4x4
Posted July 24, 2008 - 04:34 AM
seen this on a couple of WR's and YZ's, the likely culprit is right in the area of #15 on the following pic.
If #15 and #26 are worn or missing your tank is not supported and spaced off the frame properly - you also want to make sure that #12 is being used, it provides the right amount of tension which a wire or other jerry rigging will not.
  • King_Air
Posted July 24, 2008 - 05:38 AM
This is somewhat common on these bikes. My OEM tank did the same thing in 2005. I replaced it with a Clarke. I had no issues with fitment, and no problems since. If I remember correctly it was around $185.00 USD. Good Luck!
  • cowboyona426
Posted July 24, 2008 - 06:40 AM
Replace the tank with another one and you probably won't ever have the problem again. The "welding" the shop is doing is probably weakening the areas around where they are working, so it will just keep getting worse. Clarke and IMS both make good tanks, no need to buy one from Yamaha.
  • sneal06
Posted July 24, 2008 - 03:39 PM
I agree my tank did the same thing about 6 months ago, go with the aftermarket tank, I love my clark which i found here on tt and for a great deal i might say.
  • nathanyzf426
Posted July 24, 2008 - 08:39 PM
mate thats exactly where the crack is above the first rubber mount which u stated i got my tank bak today seems to be ok much better job then the first time he done it also taking into consideration which another post has been placed it most likely is weakening the tank if it does it again i will buy an aftermarket cheesr for the help nathan
  • nathanyzf426
Posted July 25, 2008 - 06:49 PM
well any ways the friggin thing split again had one all priced up on tt so ill be buying one soon works out roughly 302 dollars aud delivered half the price i been quoted here in au sounds good to me but really would like to know if the colour is going to be the same any help would be good thanks.....
  • cowboyona426
Posted July 25, 2008 - 08:33 PM
Clarke and IMS tanks are both very good on color match so you should be set. I'm not surprised it split again, in fact I think I predicted it :ride:
  • skthom2320
Posted July 26, 2008 - 02:37 PM
Don't buy an OEM tank!!! it will just split again.
I also went with the Clarke tank. Worked great, never had another problem.
  • On January 15, 2017
  • Hot  47 replies
