Convert WR 400 To Electric Start
12 replies to this topic
  • chambers
Posted July 23, 2008 - 06:38 AM
IS there anyway that a WR400 can be converted to an electric start? What parts would be required or would it be more hassle than its worth?
  • PBDBLUE
Posted July 23, 2008 - 07:26 AM
No. Do a search. It's been discussed numerous times in the past.
  • DGXR
I thought WR's came with e-start...?
  • CAVSCOUT96
Posted July 23, 2008 - 07:32 AM
The 400's and 426s did not. Aftermarket conversions were all impractical due to extreme weight and cost. Easiest way to convert... get a 450.
  • creeky
Posted July 23, 2008 - 05:13 PM
It's not worth it. Just keep that right leg in shape, freebie.
  • Just_a_trail_rider
Posted July 24, 2008 - 11:51 AM
I am beginning to realize that e-start, while nice, isn't absolutely necessary. I have a yz250 that I ride now. I have to kick it. Knowing that, I try harder not to stall it. When I do have to kick it, its not a big deal.
I think that a properly jetted wr450 is as easy to kick start as a yz250.
if your wr400 is all setup for you, I wouldn't trade it for e-start.
  • brad the best
Posted July 24, 2008 - 08:06 PM
i only use the e-start on my 450 if i screw up in a creak of something . like maybe once a month . you don't really need it .
  • yz-dwg
Posted July 25, 2008 - 06:06 AM
I must be a big screw up 'cause I use mine all the time....I do fall down alot....:ride:
  • GCannon
Posted July 25, 2008 - 07:11 AM
Maurice is right on here:thumbsup:
Being the proud owner of a 426 I find that if you turn up the idle when in rocky technical section it helps a lot with the stalling.
A properly tuned WR should start first kick every time:banghead: ( you guys did not need me to tell you that)
Posted July 26, 2008 - 12:02 PM
Shhhhh.... on the idle thing.
I sometimes race my 450 in enduros and that's my little trick. It doesn't mean anything with the amateurs and experts, but with the beginners and a few of the novices, it makes me look like I know what I am doing. (when I don't!)
You definitely got to cover that rear brake though. turning up the idle kinda neutralizes the engine braking.
  • ncampion
Posted July 27, 2008 - 07:41 AM
A Rekluse clutch takes care of the stalling thing.
  • turbohead
Posted August 08, 2008 - 12:40 AM
You don't need to spend all that money and spannerwork to get an e-starter on a WR400. An Edelbrock carb is much cheaper and easier to install. You can forget all Keihin related problems and get a bike so easy starting it's just like a dream. And it's lighter, too...
  • ParrotJuice
Posted August 08, 2008 - 02:51 AM
with some creativity, you might be able to convert the kick starter gear into a e starter, but then you wouldn't have an e start
