Anybody know a Welder around the Hillsboro, OR area who could help me out? *pictures*
26 replies to this topic
  • Luigic81
Posted 22 July 2008 - 09:18 PM
looking for a welder who can help me out with this small hole in the trans.
  • aakmetz
Posted 22 July 2008 - 09:22 PM
is that an inny or an outy did somthing hit it or did somthing from the inside escape?
  • Luigic81
Posted 22 July 2008 - 09:23 PM
chain broke at very high rpm
  • spin05
Posted 22 July 2008 - 09:25 PM
I dont think that material is weldable...Try JB weld.We use to use that in the 80's..
  • Luigic81
Posted 22 July 2008 - 09:30 PM
If I had a nickel for every time I heard that :busted:
because the trans oil could leak I would rather have that part welded, there is also a hole near the FW cover as seen in the first pic, I do plan on JB welding that.
  • pdx_munkel
Posted 23 July 2008 - 08:28 AM
I thought Yamaha's were silver down there, did you get a special model with brown and black cases? Just saying.....
  • Luigic81
Posted 23 July 2008 - 09:10 AM
hey why dont you go break your toe or something :busted:
  • cumminsman
Posted 23 July 2008 - 10:00 AM
Welder for what?:excuseme: I don't see anything unusual....it's a Yamaha right?:p
  • threeaces
Posted 23 July 2008 - 10:31 AM
Try "Cycle Metrics"
503-292-5510
10410 NW Thompson Rd
Portland, OR 97229
I had an old CR250 case fixed there quite a few years ago. They did a great job. They seem to be good at the odd / custom jobs.
  • 06crf_er
Posted 23 July 2008 - 10:46 AM
ah... those RPM's weren't that high:excuseme:
  • Luigic81
Posted 23 July 2008 - 01:25 PM
threeaces said:
Try "Cycle Metrics"
503-292-5510
Portland, OR 97229
Thank you, I will give a call :applause: good gas for you
shut up you :bonk:
  • Kyron
Posted 23 July 2008 - 02:04 PM
Then I let you in on the "better" way ........
Foil backed duct tape covered with jb weld.
The metal is cast and very hard to weld.... your going to have to empty the cases for it to be welded....
  • cumminsman
Posted 23 July 2008 - 02:11 PM
How would you know........oh wait, you were the one that caused the damage.
  • Luigic81
Posted 23 July 2008 - 02:17 PM
couldnt the foil backed tape get a hole etc.. in it fairly easilt though? Or does hte JB weld make it hard/strong? Someone else recomended a coke can
  • scone367
Posted 23 July 2008 - 02:23 PM
some cases have maginese(sp?) in the aluminum, so be careful. I would take it to a place that does TIG welding
  • 06crf_er
Posted 23 July 2008 - 02:28 PM
An poorly maintained chain caused the damage. I just happened to be on the bike when all hell broke loose.
Happen to notice the condition of the chain in the first page of this thread?
  • 06crf_er
Posted 23 July 2008 - 02:30 PM
If not, I'll refresh your memory. It's not as if I don't feel like shit for being the one on the bike when it happened. Maybe a little more grinding of the salt into the wound will help though.
  • Ride
Posted 23 July 2008 - 03:29 PM
Had a friend with a similar problem. To weld it right you need to completely disassemble the engine down to just the case. Get it super clean and take it to someone that is very good.
JB weld it and never worry about it again.
  • ticketgetr
Posted 24 July 2008 - 01:20 PM
You could try Franc Lyons of Lyons Technical Machining. He does a lot of sportbike machinig, so he is familiar with the cases. I had him weld up my trx450r case when I failed to keep a close eye on my non o-ring chain stretch. :banghead: :banghead:
He's located in Aloha last I knew of.
His business number is 503/430-5630
  • Luigic81
Posted 24 July 2008 - 01:44 PM
cool thanks! I'm gunna try to JB weld it first I think and see how it hold up.
