YZ426 light kit
8 replies to this topic
  • M0SSLAGER
Posted July 16, 2008 - 12:46 AM
Hey guys, I want to put a 8" light on my YZ426 and can't find a complete kit out there. I checked Baja Designs and E-line. I can find kits for the 450's but nothing for the 426... but I know there something out there because I have seen many of these bikes set up the way I want to do mine. What are you all doing?
  • bigdanner
Posted July 16, 2008 - 03:32 PM
You can use the stator, flywheel, and CDI unit from the same year WR to get the lighting power. Once you have the output you could run a 100wt halogen or a single HID (if you want to spend the money!).
  • M0SSLAGER
Posted July 16, 2008 - 05:57 PM
Don't I need a battery to run an HID... I was told the HID won't run off a stator only. I can't see where you can fit a battery on the YZ.
Posted July 16, 2008 - 07:58 PM
It won't run off of AC, but that means you need a rectifier, not a battery. You need a rectifier to run with a battery anyway.
  • bigdanner
Posted July 17, 2008 - 03:24 PM
The battery doesn't have to be very big. Baja Designs uses a small 700ma nicad battery with their HID lights. If you do a lot of tight trail riding you may want to use a slightly larger battery so it won't discharge quickly when you're in low RPMs.
  • crazyal426
Posted July 18, 2008 - 12:06 PM
They do not make them for the 426 anymore. There is one on the classifieds on TT. I scored my e-line 200 watt on Ebay. You do need a dc rectifier to run HID and a little battery. The NiCad is a good compact choice. The WR stuff does OK, but if you can score the e-line external mag, that is a better way to go. Good luck.
  • desertyeticheyenne
Posted July 26, 2008 - 11:25 PM
Can the E-Line 100 watt external stator be rewound for more output, or will it be sufficient as is to run a single 8" Baja Designs Halogen?
Any info will be appreciated. Thanks.
  • crazyal426
Posted August 06, 2008 - 09:54 PM
The eline external has 2 100w output wires. They are actually 90w and 90w or 180w if you use just one of the yellow output wires. I am not aware of any external 100 watt single. I have only seen the 200w. 100w should run the halogen. Good luck!
Posted August 10, 2008 - 09:29 AM
Thanks for the info crazyal, I have decided to go with the WR stator. The guy with the E-line on TT classified does not respond, nor does the guy parting out a WR? I truly appreciate the helpful info.
  • Hot  50 replies
  • Hot  113 replies
  • 0 reviews
