i need help
5 replies to this topic
  • corywr400f
Posted July 15, 2008 - 04:30 PM
i have a 1998 wr400f and i am looking for a way to get better bottom end out of my bike if anybody knows i would like the help thanks
  • WR450FGreg
Posted July 17, 2008 - 02:11 PM
Cory,
I have seen bolt-on flywheel weights advertised for four-stroke bikes that apparently boost bottom end power (probably at the expense of top end).
Not sure how well they work (maybe brilliantly, I don't know).
They look very easy to fit.
Worth considering.
Greg
  • lilyamaharacer9
Posted July 17, 2008 - 02:15 PM
Cory,
Worth considering.
Greg
a flywheel weight will only make the bike take longer to rev up and hit smoother than without it not add bottem end.
For bottom end get a pipe, but your best bet would be porting
  • Bladerunner426
Posted July 17, 2008 - 02:32 PM
Have you done any thing to the bike yet, Exhaust, jetting, Gearing, Air box mods? If the bike is all stock then there is a bunch of stuff you can do to help the bottom end.
  • Birdy426
Posted July 17, 2008 - 09:46 PM
Try running WR timing...or a high compression piston...or a big bore kit...
  • WR450FGreg
Posted July 17, 2008 - 09:57 PM
Your are dead right ... I wasn't thinking !!! (Rushed the response). :thumbsup:
The increased flywheel inertia should have the effect of making the bike more "tractable" and less inclined to stall at low revs.
If you do a lot of low speed "chugging" in tight-going it would (in theory) make the bike a lot easier for you to ride in these situations I guess.
Never tried one or seen one on a bike myself but they sound like they'd work to a certain extent.
Depends on the weight of the unit I suppose.
Greg
