YZ426F help pleaseeee
2 replies to this topic
  • BRY_426F_
Posted July 11, 2008 - 09:43 AM
:thumbsup: :bonk: Okay well I have a 426 year 2000 and it pukes my coolant everytime i go out. It is leaking from the gasket on the waterpump/case cover area. it is also leaking from the little hole on the underside of my waterpump. I have even seen a few dribbles come out from a hole on the side of the head..:thumbsup: :thumbsup: IDK what it is... I have bought a replacement gasket but I'm not so sure water should be coming from my case in that area.. but then again I could be wrong.. That is why I am here. So any advice would be greatly appreciated1!!:thumbsup:
Posted July 11, 2008 - 09:52 AM
The hole on the underside of the water pump is an escape port put there to allow oil or coolant leaks at the water pump impeller shaft to escape without cross contaminating the other fluid supply. It means the colant seal has failed, and the shaft may have a groove worn into it that will necessitate its replacement as well.
  • BRY_426F_
Posted July 12, 2008 - 10:11 AM
SO YESTERDAY i MADE A TRIP TO MY LOCAL YAMAHA AND BOUGHT THE 2 SEALS THAT GO BEHIND THE IMPELLER hopefully this fixes the problem. and I plan on replacing the gasket between the case cover and right crank hopefully this fixes my problem. thank you for the info
  • Hot  50 replies
  • Hot  113 replies
  • Hot  47 replies
