Quiet down the Beast-Looking for baffle/damper
5 replies to this topic
  • hazey123
Posted July 10, 2008 - 01:05 PM
Hey Gang, I bought a 02 wr 426 and love the power. I do however need to quiet her down for when I need to ride behind the neighborhood. The previous owner removed the muffler insert I think its called a baffle? Does anyone have one that they removed that they want to sell or donate to a fellow rider?
Also, will I need to change the jetting or anything else when I reinstall the insert? The PO changed the main to a 170 and it is running fine now. I would like to be able to use it when necessary and pull when it isn't but only if it doesn't require a jet change or any other tweaking.
Thanks Gang!
  • William1
Posted July 10, 2008 - 01:26 PM
You probably will need to go down a main jet size with insert in and possibly lower the needle a clip too. But get the insert and try it before you 'mess with the jets'. Suddenly, I see Natalie Wood in my head......
  • swede426
Posted July 10, 2008 - 01:34 PM
Thanks Gang!
I dont know if you have welding knowledge. but I did cut mine up and removed the stock insert and made another that I now can take out and put in depending on where I ride and the only tool I need is a 10mm wrench(one 6mm bolt).
  • JSanfilippo
Posted July 10, 2008 - 07:34 PM
lowering the clip raises the needle thus making the jetting fatter not leaner
  • creeky
Posted July 11, 2008 - 02:44 AM
These people www.powerpartsplus.com have an insert for WRs that works very well. The part # is GYT-5TJ93-75-00.
  • husqvarnarider
Posted July 11, 2008 - 03:25 AM
Yeah, I run the GYT-R insert in my WR 400. Quiets it down substantially, but still has plenty of power. Very easy to remove/replace also :thumbsup:
