Any Mopar tranny experts out there (Dodge Grand Caravan)?
2 replies to this topic
  • MN_Kevin
Posted May 29, 2002 - 09:08 PM
This thing has been into AAMCO 7X now. Apparently the speed sensors are failing continuously, usually 2-4 hrs of life.
Now the POS computer DOES NOT recognize a transmission installed... :)
Does ANYONE offer a manual trans kit for this thing? How about a Turbo350 (with LOTS of adapters) install kit?
  • lewichris
Posted May 29, 2002 - 09:26 PM
drive it over a cliff. they suck. My parents have one and they have put two motors and three tranny's in it. It smokes blue smoke all the time. Buy a pinto. they are bullet proof and everyone will point their finger at you and laugh.
  • fastmonstr
Posted May 29, 2002 - 10:04 AM
What year and what engine? There are many TSB's listed in my ALLDATA system for the transmission.Give me some more information and I will see what I can find. Doe's it set any trouble codes(DTC'S)?Any other symptons?
See the folling TSB on the connector for the speed sensors:
Speed Sensor - Intermittent Loss of Cruise Control
Number: 21-06-99
Group: Transmission
Date: April 2, 1999
SUBJECT:
Intermittent Loss of Speed Control
OVERVIEW:
This bulletin involves replacing the input and output speed sensor connectors.
MODELS:
1989 - 1995 (AA) Spirit/Acclaim/LeBaron Sedan
1989 - 1993 (AC) Dynasty/New Yorker/New Yorker Salon
1990 - 1993 (AG) Daytona
1990 - 1995 (AJ) LeBaron Coupe/LeBaron Convertible
1992 - 1994 (AP) Shadow/Shadow Convertible/Sundance
1990 - 1991 (AQ) Chrysler Maserati TC
1989 - 1995 (AS) Town & Country/Caravan/Voyager
1990 - 1993 (AY) Imperial/New Yorker Fifth Avenue
1993 - 1995 (ES) Chrysler Voyager (International Market)
1995 - 1999 (FJ) Sebring/Avenger/Talon
1996 - 1999 (GS) Chrysler Voyager (International Market)
1995 - 1999 (JA) Cirrus/Stratus/Breeze
1996 - 1999 (JX) Sebring Convertible
1993 - 1997 (LH) Concorde/Intrepid/Vision/New Yorker/LHS/300M
1996 - 1999 (NS) Town & Country/Caravan/Voyager
1997 (PR) Prowler
NOTE :THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 41TE/AE BUILT BEFORE AUGUST 8, 1998 (MDH O8O8XX) OR 42LE TRANSAXLE THROUGH THE 1997 MODEL YEAR.
SYMPTOM/CONDITION:
Intermittent loss of speed control condition persists after either the transaxle input speed sensor or output speed sensor has been replaced. The sensor connectors should be checked for spread terminals.
DISCUSSION:
The input/output speed sensor supplier changed effective with the 1998 model year for LH vehicles and August 8, 1998 for 41TE/AE equipped vehicles. The terminal layout is slightly different between the old and new sensors. When a new sensor is installed on an early vehicle the connector terminals may be spread from the original sensor and may cause an intermittent speed control condition. Anytime a new sensor is installed on an early vehicle the connector must also be replaced.
PARTS REQUIRED:
1 05014469AA Wiring Repair Package, Input Speed Sensor
1 05014471AA Wiring Repair Package, Output Speed Sensor
REPAIR PROCEDURE:
1. Disconnect and isolate negative battery cable.
2. Raise vehicle on a suitable hoist.
3. Locate and disconnect the input and/or output sensor connectors.
4. If required, detach the harness clip above the input/output sensors and detach the O2 sensor fastener (Christmas tree type fastener).
5. Remove the end tape from the input/output harness and push back the convolute tubing.
6. Cut the harness just above the top of the connector to remove the input and/or output connector.
7. Remove approximately 1/2 inch of insulation from the end of the two wires.
8. From the wiring repair package, locate the wiring repair harness. Approximately 1/4 inch of insulation has been removed from the repair harness wires.
9. Place a heat shrink tube over each of the two wires on the repair harness.
10. Using Miller Crimp Tool # 8272 or equivalent, crimp the splice band to the transmission harness and repair harness wires. Repeat procedure for the second wire.
11. Solder the connection together using rosin core type solder.
12. Center the heat shrink tube over the splice joint. Heat using a heat gun until the tubing is tightly sealed and sealant comes out of both ends of the tubing.
13. Cover wires with attached convolute and add additional convolute from the repair package.
14. Tape ends with black electrical tape.
15. Route engine harness behind the coolant lines and dipstick tube, away from the exhaust.
16. If required connect O2 sensor fastener and attach upper harness clip.
17. Connect input/output sensor connectors.
18. Connect negative battery cable.
19. Verify transmission systems are functioning as designed.
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: 08-90-99-93 Wiring Harness Repair 0.5 Hrs.
FAILURE CODE: XX - Service Adjustment
