Pre & Post Ride Maintenance & Inspection
5 replies to this topic
  • 05-WR450F
Posted July 09, 2008 - 02:52 AM
I have an 05 WR450. What are the common things that should be done pre-ride and post-ride?
  • matt4x4
Posted July 09, 2008 - 03:41 AM
Tire pressure
Wheel bearings (side to side play)
Brake pressure
Cables
Pads
Air filter unless you have a specified cleaning interval
Chain slack/condition (sprockets too)
Oil level/condition
Look for leaks on forks, engine, shock
Check all visible bolts
Gas level
Clear/open carb/engine vent lines
Make sure suspension works properly - can also be tested on first jump - more fun that way.
Post ride - Besides checking for leaks - I don't do anything until it's clean, then the same as above - therefore it's ready to just ride the next time.
  • CAVSCOUT96
Posted July 09, 2008 - 09:01 AM
what he said ^^^
  • face_plant
Posted July 09, 2008 - 10:20 AM
lube chain/check coolant
  • GCannon
Posted July 09, 2008 - 10:56 AM
Spokes? I don't tighten them every ride but I do check them
  • INJURY_69
Posted July 09, 2008 - 05:34 PM
Tclock
T=tires And Wheels
C=controls And Cables
L=lights And Electronics
O=oil And Fluids
C=chassis And Chain
K=kickstand
