'08 WR450F rear shock "topping out" ???
5 replies to this topic
  • WR450FGreg
Posted July 08, 2008 - 12:51 PM
I haven't investigated this properly yet, I just noticed it when I parked the bike after a wash last night.....
I lifted the rear end and felt a bit of a "clunk" at full extension. Not extreme, but definately there.
I couldn't hear/feel it yesterday when jumping it on an MX track.
Maybe it's normal, I don't know. This is my first dirt bike in a lot of years.
The bike has 700km on it and yes, I have had the rear end apart and re-greased it all, tightening all the bolts to the specified torque.
Your thoughts?
Greg
  • matt4x4
Posted July 09, 2008 - 03:50 AM
You'll need new linkage or shock bearings - it's one or the other that's clunking - easy and cheap fix, but you should go as far as taking the shock out to see which ones need replacing - once you've done that, you might find your swingarm is in need too - many times, when one is gone it means all were neglected.
  • YamaLink
Posted July 09, 2008 - 06:06 AM
Ditto. My guess is the bearing that the 17mm nut on the relay arm attaches to, but like Matt4x4 wrote, you never know til you take things apart.
A good source for bearing info is at http://www.motorcycl...cycle-parts.htm
Find the part, the bearing and part number.
  • beezer
Posted July 09, 2008 - 06:09 AM
I doubt anything is wrong. It's a brand new bike.
If it were me I'd check the all the linkage and shock bolts and then I'd go riding.
  • SXP
Posted July 09, 2008 - 07:04 AM
Your thoughts?
Greg
Greg - What you describe is typical of a worn out Heim joint (the semi articulating bearing) at the bottom of the shock. But with just a little more then 400 miles on the bike it sounds unlikely. The only thing I can think of, is something was not re-assembled correctly when you regreased your suspension. Make sure the two grease seals and collars on either side of the lower Heim joint are on the shock. I remember the collars falling out while re-attaching the shock.
  • WR450FGreg
Posted July 09, 2008 - 12:54 PM
Thanks guys.
Yeah, I might check that out SXP. Cheers.
Greg
