I tried a search and no luck.(I've been proven wrong more than once tho.:bonk: ) Is it possible to change the dash light from orange to say blue? :excuseme: Thanx
Dash Light (change color??)
Started by DaRealDill, Jul 07 2008 10:08 PM
15 replies to this topic
Posted 07 July 2008 - 10:08 PM
Posted 07 July 2008 - 11:36 PM
Not 100% sure but it may just use a neo-wedge type bulb, if so very easy to replace. Every color under the sun, and cheap. Most bulbs are under $3.00
Posted 08 July 2008 - 12:16 AM
Sounds to good to be true !!! :lol: Have you or anyone else pulled the dash and seen the bulb before?? :excuseme:
Posted 08 July 2008 - 02:41 AM
AFAIK there are leds inside! if you get some SMD leds from lets say blue VW dash maybe you can solder those in your drz dash
Posted 08 July 2008 - 01:08 PM
It is very tricky to do. If you are not familiar with soldering SMD components, you should not attempt it.
Posted 08 July 2008 - 01:29 PM
if you know some one that is good at modding cellphones ware they install diferent lights
they can do what your asking
Posted 08 July 2008 - 03:26 PM
they are SMD? i think im gonna change mine. i used to be the "please solder these smd componants for me cause im to old and cant see" guy at my old job
Posted 08 July 2008 - 03:39 PM
Be sure to know what you do, the odometer is expensive. Dealer changed mine and it was something like 800$
Posted 09 July 2008 - 12:51 AM
Thanks for the info guys, Think Im gunna pass on it. If it was just a bulb swap then I would go for it. Thanx for saving me the headache of pulling dash!!! :lol: :lol: :lol: :lol:
Posted 09 July 2008 - 10:56 AM
Dang, I seen the thread title and I to was hoping it was just a bulb change.
Posted 09 July 2008 - 12:32 PM
just change to a vapor...much easier and has the blue light already there
Posted 10 July 2008 - 11:11 AM
Vapro???? I'll try a search on that one. I'm guessing a aftermarked dash.
Posted 10 July 2008 - 12:04 PM
yep, trailtech vapor. Aftermarket dash/computer. Available at the thumpertalk store. Blue backlight, also has a tach, engine temp gauge, ambient temp gauge, odo, and stopwatch, etc.
