my DRZsm is driving me INSANE!!!OMG
55 replies to this topic
  • urymoto
Posted 07 July 2008 - 04:02 PM
i just installed the FCR a few days ago...and this thing act like ***.king Jekyl and hyde...
it runs perfectly, all jetting is perfect, no surging, and not much backfiring..very responsive
but once in a while, after a little bit of riding it just dies, for no reason....at first i though my idle was too low, and once i would pull the clutch in it would die..so i made my idle higher..and now...BAM, it dies...
all the cables are connected, and there is still alittle gas splashiong in the tank...
i did manage to turn it on a few times, but it just died the second i let go of the gas...
while i dirve its a dream...now its a nightmare
  • urymoto
Posted 07 July 2008 - 04:08 PM
btw is it possible i ran out of gas? i was on reserve without knowing it....and it did just dead stall on me, BUT i still hear gas in the tank when i shake it...is it possible?
  • stringburner
Posted 07 July 2008 - 04:09 PM
Very possible. :ride: Put some gas in it and see what happens.
  • HotCorner
Posted 07 July 2008 - 04:56 PM
Sounds like excellent advice to me.
  • urymoto
Posted 07 July 2008 - 05:19 PM
it turned on, but i barely limped home....no idle, main jet is bogging...didnt used to...its nuts...i dont get it..vacuum cable not kinked...
  • robklx400
Posted 07 July 2008 - 05:21 PM
Does your fuel line make a straight line, or does it make a turn?
Mine acted like that until I spun the fuel inlet & made a straight run.
  • stringburner
Posted 07 July 2008 - 05:22 PM
Sound advice indeed. :smirk:
  • urymoto
Posted 07 July 2008 - 07:24 PM
it makes a turn..but so what? i mean, in terms of physics what effect would that have...
my main jet is ***.ink up now as well1!!!! i dont get it
thanks ill try it
  • iowaBClivewire
Posted 07 July 2008 - 07:26 PM
are you trying to run it on deazel ???
I'm not really joking
if the gas was just sitting around for aney time at all you need fresh
  • iowaBClivewire
Posted 07 July 2008 - 07:27 PM
try runing with the gass cap off too
  • urymoto
Posted 07 July 2008 - 07:28 PM
i have no idle....none at all, i dont even know how i dorv eit home...i kept on the gas at the large intersections, and went thought the reds at small ones...just to limp home. and when i would crak the throttle, it would surge big time....
  • urymoto
Posted 07 July 2008 - 07:29 PM
no diesel, tries running without gas cap as well
  • dirtwiz
Posted 07 July 2008 - 07:47 PM
Check to see if your fuel screw is still in your carb...there have been a number of people who put a fuel screw in that was not a tight fit and when it fell out they had a similar problem.:mad:
  • urymoto
Posted 07 July 2008 - 08:05 PM
hmm, but i had i turn off before..adjested the idle, and it went away..so it adds to the mystery...if i lost the screw ok..it would explain the present problem...but not yesterday it went dead twice, and then ran ok...
  • urymoto
Posted 08 July 2008 - 04:43 AM
anyways..if anybody else has something, please feel free...thanks
  • Bluemarlin04
Posted 08 July 2008 - 04:49 AM
My bike did the exact same thing. IT drove me nuts, I had no bike for two weeks trying to figure it out. I checked everything in the carb. Turns out my oil had gas in it from sitting. Dont know how it happend, I suspect sitting around for a month fromt he previous owner. Check it out, I changed my oil and my bike was fine. Now I disconnect the gas line if it sits for more than a few days.
  • RetroRanger
Posted 08 July 2008 - 05:03 AM
I would clean the carb maybe you picked up some sediment while on reserve
  • Regalman
Posted 08 July 2008 - 05:18 AM
Honestly, you would probably be better off fixing the problem rather than try to bandaid it.
  • obrianmcc
Posted 08 July 2008 - 05:25 AM
Try an in line shut off it you are still worried about it sitting......
  • urymoto
Posted 08 July 2008 - 05:59 AM
it never sat for more than a few hours....maybe it sucked some crap in
